Home > Technical (L322) > Heated Seat Problem - 2007 TDV8 Vogue SE
Page 2 of 3 <123>
that first code is an airbag error.. ... - .- -.
Post #358305 23rd Nov 2015 5:38pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Thanks for the prompt answer. Code is from Iid tool and it goes oon to say drivers seat Second code goes
Onto say drivers backrest. I will upload pictures 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #358313 23rd Nov 2015 5:59pm
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #358352 23rd Nov 2015 7:46pm
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #358353 23rd Nov 2015 7:47pm
dolph34
Spoke to IID but they weren't able to identify which part. Very helpful and suggested the heater Any thoughts would be gratefully received 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #358354 23rd Nov 2015 7:49pm
dolph34
Hi all, just for anyone else with an SE L322 with the heated / cooled seats. My drivers has never worked and it turned out to be part number HHK500060. This is the blower motor for the heated part of the seat. The motor is fine but there is a 90 degree angle piece of abs / plastic that carries the air from the motor / fan to the seat. The angled piece rests against a seat spar that if you push against the seat back hard as you sit in the seat , the part can crack and the air can escape causing the motor / fan to stop because its not getting the reading it expects
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #409724 18th Oct 2016 12:25pm
dolph34
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #409725 18th Oct 2016 12:27pm
dolph34
also thanks to Axle on this forum, who replied to a PM very promptly and with good advice re this problem 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #409727 18th Oct 2016 12:33pm
dolph34
Finally a heated seat. As above new part arrived from Germany and my indie removed the drivers seat , removed the back of the seat and three screws later and a connector block and the damaged part was removed. , the new unit went straight in and panel on , seat back in and hey presto , heated seat.
The old part ( which connects the motor and fan ) is cracked and not repairable but the motor and fan are perfect , my son is asking one of his college professors if they can make a replacement part with their 3D printer. If so the old unit will be serviceable again. On opening the seat it appears the unit has been changed before so maybe a design fault if you a larger gentleman and can crush the unit against the seat spar / support.
Part cost 160 euro and indie charged 50 euro labour All in all a bargain with the cold mornings starting !!
My next cold protection fix is getting the remote FBH remote control I bought from a forum member a tele start receiver unit , next time I'll check first to see if I have the relevant part fitted before buying the remote !!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #410828 26th Oct 2016 8:26pm
Charmer
I think I may have the same problem.
Does anyone have details of how to remove the seat back and if this can be done with the seat in situ?
Cheers,
ANDREW
Post #412580 7th Nov 2016 6:55pm
dolph34
Seat needs to come out to replace but if you remove the armrest you can pull back the seat back cover to see if that's the issue Taking the seat out is easy enough 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #412618 7th Nov 2016 11:54pm
dingg1
I had the same two codes plus one for the seat switch lost comms
a couple of technical taps to the seat switchgear appears to have fixed the issue - so far Laughing
Post #412659 8th Nov 2016 3:15pm
AB54FLY
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
+1 for the split pipe.
I didn't have heat (or cool) in the drivers seat for 2 years. The pipe had split in exactly the same place. I've bodged it with aluminium tape, gaffer tape and a few cable ties. To be honest it's probably tougher now than it was originally, so I'm planning to see how long the repair/bodge lasts before I consider replacement. That being said replacement is an easy enough job.
Lovely warm bum now. Thanks for the heads up.
2007 4.2SC.
Post #425676 30th Jan 2017 7:37pm
RJDS
I have cooling but no heating on the drivers seat. you can hear the fan start when you set it to heating, but then it shuts down within a few seconds. Does it use the same fan unit and sensor for both? If so I guess it must be the control module and not broken pipework in the seat?
Post #426647 6th Feb 2017 10:05pm
RJDS
Post #426649 6th Feb 2017 10:08pm
Page 2 of 3 <123>
