Home > Maintenance & Mods (L322) > Alternator change - how to release drive belt tensioner? |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
I don't know if it varies for the 4.4 but for my 3.6 and 300Tdi you simply put a socket and breaker bar on the nut and twist.
24th Aug 2015 10:22pm |
tafftoo Member Since: 29 Jan 2015 Location: Staffordshire Posts: 40 |
How did you get the belt off in the end? I'm at the same stage and struggling to work out how to rotate the tensioner to get the belt off. Expansion Tank bracket was a right PITA |
16th Nov 2015 1:39pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Hi,
16th Nov 2015 2:30pm |
I gave up on the expansion tank bracket and just moved the tank out the way, stupidly located bolts on that bracket Formerly happymadison1978 |
16th Nov 2015 2:31pm |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 |
Not sure if it's any help but I've just removed the power steering pump on a TD6 and the tensioner nut for the belt is 24mm. I used a standard 24mm ring spanner. On the TD6 at least you can access it and tension/untension the belt without removing the radiator cowl. I just moved the belt out of the way, didn't take it off completely. |
16th Nov 2015 3:46pm |
I can't even seem to get at it to get the wrench properly on the flat bits, and when I do, there's no movement left in the wrench to even start to apply leverage... How much disassembly did you do?
16th Nov 2015 4:19pm |
Ah right, I took the fan off. I was able to 'flex' the AC pipe out the way and it was a fiddle to get the fan and shroud out but that's how i did it there really isn't much space there at all.
16th Nov 2015 5:20pm |
I've got the fan spanner but I was hoping I wouldn't have to take it all out. Oh well. I'll give it a go |
17th Nov 2015 9:31am |
It's such a simple thing to remove you might as well as it frees up a lot of space. Ed |
17th Nov 2015 9:37am |
Well, I've finally managed to get the alternator swapped, but when putting the new coolant in, I noticed that it was blue and not red... Typical! I've reason that the wrong coolant is better than no coolant especially in the short term, but does anyone know what kind of issues it will cause and how long I've got before I need to flush it and refill with the correct coolant? |
23rd Nov 2015 9:36am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Mixing the types is poss worse - it causes a reaction and leads to a sludge substance.
23rd Nov 2015 11:17am |
Booked in for Wednesday with LR to do it. I won't get chance until the weekend and I'm sick of messing with it after the alternator job.
23rd Nov 2015 12:43pm |
Just an update... LR had my car as a 2005 4.4 BMW engined V8 on one of their systems which was why I was sent the wrong coolant. They've now double checked and confirmed that I'm not going mad, that I'm not missing or surplus a supercharger, and are doing the coolant flush and change at no cost to me.
24th Nov 2015 5:47pm |
Good to hear!
26th Nov 2015 12:56pm |
