Home > Maintenance & Mods (L322) > How many FFRR members does it take to change a lightbulb...?
Greg66
2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Once again, looking for help.
One of the sidelight bulbs in my 06 SC FFRR has gone. It is in the cluster directly under the indicator bulb, where there are two bulbs. It is the physically larger and brighter of those two bulbs which has gone, shown here (it is the left bulb in the lower light set)
I found a vid online that shows how to remove the assembly that holds the indicator, but then realised that in the video that assembly is separate to the main headlight assembly, whereas on mine the whole thing is one single unit. So back to square one.
Any pointers to a video that shows me how to remove the assembly I have, and better still, any suggestions as to what bulb I need?
TIA
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Range Rover 4.2 SC
AM V12VS
Porsche 991.1 Turbo S
Mini JCW conv
Post #358162 22nd Nov 2015 9:53pm
the cornering bulb is a H8 type...you remove the headlight unit and get access from the back.. ... - .- -.
Post #358165 22nd Nov 2015 10:04pm
whole lamp unit comes out, remove the two screws at the top and the unit should pull out forwards..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #358167 22nd Nov 2015 10:08pm
...and a screw down the side/bottom by the grill.. ... - .- -.
Post #358170 22nd Nov 2015 10:13pm
ah yes, you have to take the grille off too.....my bad..... so 6 screws incl the grille..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #358171 22nd Nov 2015 10:22pm
Greg66
Thanks, chaps. I shall get hunting. Range Rover 4.2 SC
AM V12VS
Mini JCW conv
Post #358259 23rd Nov 2015 2:10pm
blackstoun
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
answer is 3
So far the answer to the original question would appear to be 3 members
actually 4 if you count me, but i could not contribute anything useful
Post #358281 23rd Nov 2015 4:08pm
