Home > Technical (L322) > High speed breaking seems wobbly |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7938 |
Something is wrong - it should brake smooth & straight - mine have always felt like I could brake without holding the steering wheel - no wobble or pull to either side on a flat piece of road.
22nd Nov 2015 2:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
^as above, wheel nuts then check the rear calipers for excess heat after a run to see if one is binding. Next is to check the discs and pads all round then onto bushes ball joints, and track rod ends. Any and or all can cause the judder. There is nothing that can't be fixed with a hammer😜😜
22nd Nov 2015 2:29pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Sticking caliper slide pin is also possible cause. John
22nd Nov 2015 2:39pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
I checked the wheels for excess heat as I'd read it was an issue sometimes on the rears but all seemed about the same. The discs have a bit of a lip on them and pads are getting a bit low so will change the as out first as they will need doing anyway and see how I go from there! I didn't think it seemed right to be honest.
22nd Nov 2015 3:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
The clue is in the description - "slide" If it doesn't slide easily it won't work! Yes, when you change the pads you will have the guide pins out so you can check to ensure they move easily and work as intended. They are likely to be all gunked up with black stuff. I usually clean them up all shiny (blunt knife then wet and dry paper) and refit with some "Copper Ease" (not too much!) or similar. You will also see if you have one side of the caliper wearing out the pads more than the other, a good clue that something is sticking, and whether you are able to easily push the piston back in to install the new pads. Also worth having a good look at your discs, see if the are still "true", even if not requiring replacement due to thickness/thinness. .
22nd Nov 2015 4:04pm |
Thanks joe will just replace the discs too as they are fairly old looking at them, at least I will know that I have everything new on all corners! Don't want to take any chances topping something that size! Hopefully that will resolve the issues if not its onto the suspension checks.
22nd Nov 2015 8:33pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Had the same issue on mine, rear caliper pin was tight. Wasn't even too bad to be honest but made a huge difference once freed off. |
22nd Nov 2015 8:56pm |
It's generally not the calliper itself which sticks, it's the caliper carrier which corrodes and grips the pad which stops it freeing off when you take your foot off the pedal. There is nothing that can't be fixed with a hammer😜😜
22nd Nov 2015 9:11pm |
Well I have now replaced the front discs and pads and they were all fine the back ones were a different story.
17th Dec 2015 4:16pm |
I'm trying to remember, but I'm fairly sure I had sticky rear callipers on my 07 - they needed replacing but think they were refurb units & I had to return the callipers that I removed.
17th Dec 2015 4:34pm |
The Pins are part of the caliper carrier not the actual caliper itself. to get them you will need to buy that not the piston part. There is nothing that can't be fixed with a hammer😜😜
17th Dec 2015 5:10pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
if a Blow torch and a suitable drift wont do it, then it;s probably a case of getting a new carrier. |
17th Dec 2015 11:15pm |
Phil303 Member Since: 23 Nov 2015 Location: East Anglia Posts: 47 |
Definitely brakes. I had something similar in my old S8. Only happened at high speed braking; pottering around town it was unoticeable. |
18th Dec 2015 11:25am |
Thought I'd give an update incase anyone else has similar issues. Managed to free the pin eventually using lots of persuasion and some home made penetrating fluid made up of ascetone and atf fluid which did the trick! Also used joe 90's guide and do the rear brake lines which were exactly the same on the tdv8 as the td6 so pretty easy! The braking issues have now gone and no more wobbles so was definitely the sticking calliper pins causing the issues!
19th Jan 2016 10:08am |
