Home > Technical (L322) > ride height 30 mm lower at the back
viper
Ride height is approx. 30 mm lower at the back on level ground in normal and raised setting . Is there a re calibrate method without a tool or is it best I just get my indy to fit 2 new sensors as they are cheap and reset using his equipment .
compressor shuts off about 30 seconds quick after raising
Post #353982 24th Oct 2015 6:43pm
30mm lower than "normal" for the rears, or lower than the "front" ?
Standard setting is 10mm lower at the rear than at the front, could be previous owner had them lowered?
This also might help:
http://www.fullfatrr.com/forum/topic12292.html
You will need a diagnostic tool to calibrate heights, your indie should be able to do this, save just buying new sensors (still might be needed but i would try resetting heights frist) .
Post #353996 24th Oct 2015 9:59pm
viper
thanks joe, I used your chart to measure mine. My rears are 30mm lower than my fronts , should only be 10mm , so 20mm out , it can be seen visually as well which is what made me get out the tape measure. I did measure then when I first got fatty and they were just 10mm lower at the back , which is spot on acc to your table
any point in taking them off and lube/clean and refit ?
Post #353997 24th Oct 2015 10:20pm
Certainly worth having a look to see what state they are in Thumbs Up
Don't know if they improved the design on later models but the rubber surrounds on the sensor mountings to the lower wishbone perish and disintegrate on the earlier ones. When I took mine off the rubber fell apart! Some adept use of duct tape has held them in place (the rubbers) without fault for a few years since.
So have a good look and poke about before removing, if all "seems" intact at least you have been warned of what could happen Smile .
Post #354008 25th Oct 2015 1:06am
viper
good advice thanks , I will have a poke today
Post #354050 25th Oct 2015 10:54am
viper
Took it down to Landranger services in stockport. They put it on their automate and confirmed everything was ok but need a calibration, booked back in as it can take an hour or so to complete.
took it in today and after much up and down behaviour and tape measure checking they got the car to within 5mm . very happy with their knowledge and the price was only £50 . they have a very good LR parts dept so looks like ive found somewhere local that appears to be trustworthy and a good resource
Post #357392 17th Nov 2015 12:13pm
welderman
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I used Landranger for my RRS, good service all round and very helpful when I decided to fix my own transfer box Shocked
Post #357403 17th Nov 2015 1:40pm
n1cktdv8
I'm interested if your saggy back end was a result of a tiny leak in rear bags, sensors or a previous setting?
Getting within 5mm is ok for me and I'd be happy if it sits like that without further sinking, but I think mine has a sensor issue. If I leave it for 2 days or more without moving it I notice the rear will drop equally side to side, not just one corner - this makes me think it's not a bag.
What fettling did the boys at L'ranger do. Pal of mine, his lad works there. Is this where I put the car details and a bit about myself ?........
Post #357444 17th Nov 2015 5:59pm
I have my rear end set 10mm up, otherwise it looks like the car is always falling backwards. As it is now, it seems to sit properly. .
Post #357457 17th Nov 2015 7:08pm
viper
they gave my air suspension a check over read the volts from the sensors ect and were happy it was just a calibration issue..its been 30 mm lower since I got it 10 months ago, whatever height I set it at its always the same amount out.
Joe, ive actually got them to set it the same height on the back as at the front and not the usual 10 mm lower , looks better.
Post #357521 18th Nov 2015 12:19am
Zirconblue
Re: ride height 30 mm lower at the back
Or is it 30mm higher at the front?
What i mean is you need to measure all 4 corners and work out where they are in relation to where they should be.
Post #357522 18th Nov 2015 12:30am
GraemeS
Remove the 20A suspension system fuse to prevent (downwards) levelling whilst parked. You will then know whether the leak is one side bag or air-line or the valve block if both sides.
Post #357524 18th Nov 2015 1:36am
viper
as ive said, I checked the dimensions against Joes chart , definitely the back was out , its all spot on now
Post #357663 18th Nov 2015 10:55pm
