![]() | Home > Wheels & Tyres > TPMS Retrofit |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Look |
There is a receiver inside each wheel arch it's an oval metal arial thingy and the subsequent wiring harness to connect them all to the module and there is a fifth receiver somewhere in the roof lining or near the rear view mirror I believe . 2008 MY Supercharged
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Given the number of people that have had issues with the factory TPMS, I'm not sure why you'd want to bother....
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
We had a blow out in the SC when towing the trailer with a car on it up the A1 last year.
The BMW Mini uses the ABS system to monitor tyre pressure. If pressure loss in any tyre occurs the difference in diameter of the tyre throws a fault on the dashboard. No sensors, no faffing about just blow up the tyres and set the system and it works |
I had a similar thing happen on the A5, picked up what I thought was a stone, for a few miles. then it all went quirt, thought that the road was badly tram lined and discovered that I'd covered about 3 miles on a flat tyre when I hit the first round about ![]() ![]() I didn't know anything until I got to the R/B, and I too destroyed a less than 5000 mile old tyre ![]() ![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Fair enough ![]() I'd still question why the system was disabled though - there must have been some sort of issue.... There are plenty of after market kits like the ones miggit linked to - some that will do the trailer wheels & temps too - I'd be more inclined to go with something like that than try to retrofit a LR product ![]() |
The Golf R32 I had used the ABS system to detect the tyre pressures, a much better system then these valves!
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Just don't bother is my advice, TPMS is always problematic, I hated it and so glad my SC AB doesn't have it. Discovery 4 HSE
If you really want to do it, then get it working on the old car first - do you have an IID to re-enable it ?
This very similar to mine, the only difference is my display is a small unit , looks like a stunted sat nav, and requires wiring in to the car, this one just plugs in to the cig lighter, which I assume is still in the console near the gear select, and would be easy to see |
