![]() | Home > Maintenance & Mods (L322) > Diff - did you? I did! |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
1. Nope, maybe I should have
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
^ 1,2,3 what holidaychicken says |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
1. Why? Not advised on MY02?
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
1) yes, I did, but it didn't seem to get any more oil out.
http://workshop-manuals.com/landrover/rang...page_1452/ The manual note on the above link suggests rotating the wheels to ensure that any remaining oil contained in the Diff is basically allowed to find its way out via the drain hole whilst the drain plug is out and before putting new oil in. Suppose if you're draining to a measure and the recommended amount drains out, then it's reasonable to assume it's pretty much all out. I'd also read someone referring to taking the front passenger wheel off for easier access so as to refill the front Diff, if you have axle stands but not the luxury of a ramp or pit. My refill kit has a short hose/ nozzle and so I've since tried the wheel off suggestion just to weigh up access; and for my kit, it will be a lot easier for me just to remove the front passenger wheel and get refill access that way, as opposed to crawling under the car to try and refill, which might well get messy based on my short refill hose! ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
As mine was done on the road side (with a camber) I drove the nearside onto some blocks of wood to get the car level and then raised the suspension. It's not especially difficult to get at the diff bungs with the wheel on, either from the front or from the side.
Well, it's draining off overnight pending my refill in the morning... and I'll be using the original drain plug because I've been sent a new filler plug instead of a new drain plug |
Job done. Raised and rotated both wheels but nothing more drained out, although I'd left it to drain overnight.
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Which oil did you use? 2004 L322 V8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8553 ![]() ![]() ![]() |
Can't understand why they give such a high torque figure for fill and drain plugs, just makes them ridiculously hard to get out next time or you end up damaging the threads... always just nip mine up, they are under no pressure all they do is keep oil in... never had one leak and I can always get them out again..
4.4TDV8: 1. Front Diff Oil - Castrol SAF XO 75W/90 (0.75L to refill) 2. Electronic Rear Diff Oil (electronic rear diff) - SAF Carbon Mod Plus (1.5L to refill) 3. Transfer Case Fluid - Shell TF0753 (1.5L to refill) @ Pete, I did wonder if the torque settings like they were heading towards being tight but just when I thought it'd had enough, the Torque Wrench kicked in and dud it's job! ![]() |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Anyone surprised at the 14mm front diff drain !!! Someone misreading the size in the manufacturing stage !! 2015 4.4 AB
I was a bit surprised how much bigger than the others , I just wish the diff, transfer box and gearbox were just the same fitting |
