Home > Maintenance & Mods (L322) > Poll - does your L322 have rear wheel arch corrosion? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
If like me you don't use the rear seats a lot it's worth considering applying a light smear of clear grease on the outer painted surfaces of the rear wheel arches and renew as necessary every now and again, particularly in winter.
7th Nov 2015 1:40pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
If you have the opportunity to look after the arches from new, they maybe they have a better chance of avoiding corrosion?[/quote]
7th Nov 2015 3:41pm |
Fortunately, our 2012 wheel arches are like new and so I've just spent an hour removing the original LR rubber strips (that have a metal core beneath the rubber); and I've degreased/ Iron X, then heavily greased the nooks and crannies around the arch and on the underside of the arch face before replacing the old LR rubber strips with the new plastic trims; all pretty much as recommended by NDF in the below thread and as successfully used on our last RR.
7th Nov 2015 4:50pm |
