Home > Maintenance & Mods (L322) > £600 odd to replace - good deal
pri831
Got a quote to replace upper and lower track control arms and lower ball joints on my L322 for £615.
Both sides
Sounds like a good deal? Garage is reputable
Post #355145 3rd Nov 2015 5:04pm
How much is parts and how much in labour?
the arms are about £40 for OEM (or £150 for LR gen) for the uppers and £60 for the larger lower arms OEM. per side plus the ball joints which go on the larger arms, all in probably could be done with OEM parts for £115 - £120 in parts per side plus labour.
leaves about £375 in that for labour, depending on their hourly rate, sounds about 4 hours. possibly a little bit steep, I'm sure someone in the trade will be along to say how long it should take. There is nothing that can't be fixed with a hammer😜😜
Post #355159 3rd Nov 2015 5:34pm
pri831
I haven't got the quote sheet handy - I think labour worked out at around £200. I will check the quote sheet again when im home for full breakdown
Post #355165 3rd Nov 2015 5:38pm
Zirconblue
I suppose you need to really ask if they're using genuine parts or just getting them from Eurocarparts, And is it just a general garage, main dealer or an independent specialist?
Post #355167 3rd Nov 2015 5:39pm
pri831
Its a place called Elite in Rainham. They are are wheel/tyre/suspension outfit.
I will find out if they are genuine/patent parts
Post #355169 3rd Nov 2015 5:45pm
Lemforder / Delphi parts are OEM and are OK.
personally would only go with genuine or OEM. I have taken original parts off to find them stamped with Lemforder Logos Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #355172 3rd Nov 2015 5:49pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Had this work often here in my garage, sometimes all around 2 hours, sometimes 5 hours, because of very difficult build out of the ball-Joints, very rusty! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #355261 4th Nov 2015 7:03am
