Home > Technical (L322) > Strange random problem?
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
This is a bit long winded but i will try to explain exactly what happened Thumbs Up
Last weekend we were due to take my 06my 4.2sc upto Scotland for a week. Loaded the car and filled it with fuel and set off on the 400+mile trip Cool
But then only 5 miles later got a misfire followed by a "reduced engine performance" bong Sad Sad . Pulled over and read the codes and got "cylinder 5 misfire". Cleared the fault and it seemed to perk up, so we hit the motorway and all seemed well for another few miles until an uphill section and got another bong "reduced engine performance" Banging Head but this time i wasn't in a place where i could pull over so i had to keep going, within a couple of minutes i had the following faults bong up
HDC unavailable
traction control unavailable
adaptive headlight warning flashing
low range not available
transmission fault
all within a few minutes Rolling Eyes
so we made the decision to turn around and head back home. Pulled over and checked the engine fault codes and got "cylinder 5 misfire, cylinder 6 misfire, cylinder 2 misfire, cylinder 3 misfire, multiple cylinder misfire first 1500.
So we ended up going to Scotland in the Mrs's Qashqai (and averaged 57mpg over 1600 miles Bow down )
Tried the range rover today and was spluttering and banging almost as soon as it started up. When i checked the hidden menu i was getting 13-14v but as i turned everything electrical on it dropped to 10.5v and the faults started flashing up again one after the other
When revved at a steady 2500rpm it slowly climbed to 12-12.5v but never got much higher with everything switched on
Has anyone experienced anything similar, or is it just a coincidence that the misfire happened at the same time as a dodgy battery/alternator ???
Thanks in advance
Paul Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #355076 2nd Nov 2015 10:23pm
Alternator is goosed sir... That will bring every fault code in the world up as all the ECU’s etc get underpowered! Should read 14v+ with everything switched on...
Post #355080 2nd Nov 2015 10:29pm
marsie
Boo!!! Sad
Cheers Craig Thumbs Up Paul
Post #355083 2nd Nov 2015 10:54pm
marsie
Spark plugs replaced and alternator ordered for tomorrow so fingers crossed Shocked
Paul Paul
Post #355140 3rd Nov 2015 4:42pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Good luck with it all Thumbs Up Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #355189 3rd Nov 2015 7:06pm
marsie
Changed all the plugs and took it out for a run. Misfire is still there although now its just coming up with cylinder 8 so next job is to swap the coil pack from another cylinder and see if the misfire moves or not Banging Head
Paul Paul
Post #355344 4th Nov 2015 7:31pm
marsie
Update-
Swapped the coil pack to number 2 and the misfire transferred to number 2 so replaced the coil on that cylinder and now all the ponies are back in the stable and happy bunny mode has returned Bow down Bow down Bow down
all fixxed Thumbs Up Paul
Post #355623 6th Nov 2015 10:33pm
SMUTT
Well done. Thumbs Up methodical fault finding saves the day.
How did you get on changing the alternator? Howard
Post #355624 6th Nov 2015 10:40pm
marsie
Haven't done it yet, not convinced there is owt wrong with it so may return the new one and get my pennies back Paul
Post #355632 7th Nov 2015 12:03am
