Home > Technical (L322) > Whats the big deal with DPF's ? |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
Are vehicles with these things fitted to be avoided and if so why ? |
1st Nov 2015 9:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8246 |
Well all diesels have had them for a number of years... just something else to go wrong... or buy a petrol.... Pete
1st Nov 2015 10:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Not so good on town only cars!!! |
1st Nov 2015 11:39pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1766 |
DPFs have been known to be quite problematic
2nd Nov 2015 6:40am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
As above.
2nd Nov 2015 9:19am |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
With regard to cost. My Skoda Superb needed a replacement (only 3 years old ,just out of warranty) It was about £1,600 |
2nd Nov 2015 9:20am |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 |
My current car (not LR), went for its first MOT under my ownership in Feb. The car passed but was told by the garage that the DPF box had been repaired (weld patch). He suspected that the DPF may have been 'modified' but can only pass or fail the car based on actual emissions, as these were 0.00 it passed. I have never needed to regenerate the DPF on my car but my wife's Jag needs a little 10 min run every 10-12 months and all is fine. Just the incompetent government/s not knowing what there talking about, again Just like leaded v unleaded. Cat's v lean burn. Don't get me started. |
2nd Nov 2015 10:43am |
Just to clarify this point, it's not illegal to remove the DPF from the car, and map it out But the DPF needs to be fitted for an MOT. If the DPF is missing, it "should" be an instant fail, regardless of emissions And I expect VOSA/DVSA or whatever they are called will take a dim view if you happen to be subject to a roadside check However, if the DPF looks like its there, and there are no warning lights on the dash, then who knows |
2nd Nov 2015 2:05pm |
The bigger problems arise with earlier systems that needed much higher temps to force the soot to be burned off by chemical reaction.
2nd Nov 2015 2:36pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
surely you've just contradicted yourself? I mean if it's not illegal why would DVSA take a dim view at a roadside check? I believe it is illegal to remove it if it was fitted as standard, as the car would be considered to be an unroadworthy condition. But like most of these sort of things, the chances of getting caught are probably very slim. You could as you've alluded to remove the insides of one and put a bit of pipe through the middle then refit it, and still pass an MOT as it's only a visual check. |
2nd Nov 2015 7:09pm |
If you only plod around town they clog up, as they need a regeneration cycle to clean them selves (30-40 min drive at 50+ mph). People complain as they've only used the car plodding around town or just short commutes and never take the thing for a run, so it's clogged up. (if you only plod around town, you're probably better off with a petrol for a number of reasons, as the fuel economy wont be that different anyway) Provided you go on a motorway or dual carriage way for 30 min at a time on a regular basis it shouldn't be a problem or anything to worry about. you're looking at a couple of hundred quid each for a replacement. When allowed to regenerate, the loss in performance is probably not really noticeable in real world driving. As above, it's illegal to remove them if they were fitted as standard, https://www.gov.uk/government/uploads/syst...idance.pdf but chances are you're unlikely to be caught. "It is an offence under the Road vehicles (Construction and Use) Regulations (Regulation 61a(3))1 to use a vehicle which has been modified in such a way that it no longer complies with the air pollutant emissions standards it was designed to meet. Removal of a DPF will almost invariably contravene these requirements, making the vehicle illegal for road use. The potential penalties for failing to comply 1 http://www.legislation.gov.uk/uksi/1986/1078/contents/made Version 2 with Regulation 61a are fines of up to £1,000 for a car or £2,500 for a light goods vehicle. " |
2nd Nov 2015 7:19pm |
