![]() | Home > Wheels & Tyres > Need new rims for the winter tires |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
I'm currently looking for a set of 20" winter wheels for the ffrr. The winter wheels that followed the car when I bought it this summer, was 19" HSE style with 275/45 R19 tires. The tires are in very good conditions, very little wear. However these wheels are too tiny for the car - doesn't look good IMO. It's almost as if the deployable sidesteps touches the ground when deployed... So either I have to buy new winter tires with bigger dimensions; 255/55R19 or 265/55R19 (or 275/50 R19) - or new 20" rims and tires altogether. Most interested in the last option at the moment.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
seems the right price for the product.. ... - .- -.
Hmm - I've been looking at similar wheels at ebay, e.g. this one: http://r.ebay.com/WPJlBu
it all depends how much the seller wants or thinks his wheels are worth.. ... - .- -.
TBH your better sticking with the correct FF wheels and correct tyre size rather than using sport wheels and tyre sizes. They aren't as tall IMO and not really in keeping with the car, especially for winter stuff |
Thanks for the advice - it might be that I need to reconsider this! |
I havent give up buying the 10 spoke RRS set, but I think that 275/45R20 is slightly too small in diameter for the ffrr. The max load shouldnt be a problem for these rims, similar to the ffrr.
255 is the standard width so can't see a problem with 265 , the aspect ratio surely makes no difference to fitment .I now wish I had gone up to 285/50/20 when I changed my tyres . 2008 MY Supercharged
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
I'll say it.... Don't buy the rrs set. By a ffrr set, they are out there and makes for peace of mind.
Hi fisha, when you say - have you experienced that a RRS wheel fails when used on a ffrr? The wheels I'm looking at are rated 900kg (I think that ffrr wheels are rated 950kg?), they have been used on a L320 - heavyweight vehicle that as well, but of course with slightly less total gross weight than a ffrr. I've seen from this forum and other forums that many ffrr use the 20" RRS wheels on their ffrr, I haven't got the impression that genuine RRS wheels breaks down when used on a ffrr? |
there is nothing wrong with fitting RRS wheels onto your FF as long as the tyre fitted is the correct one ..
and insurance are told... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Have I fitted one? No - for the reason given. Stamped rear axle limit is 1850kg ... technically needs a >925kg rated wheel. RRS *may* not be upto that rating - as you say, those linked at 900kg rated. I do accept that depending on the RR's use, then you may not come close to reaching that limit. Then again, I tow a horse trailer, where the dynamic loads could multiply the loadings on the axles, and in those cases, I'd rather have that extra amount. Sounds petty perhaps, and I fully accept that others run RRS alloys on their FFRR. But its not my personal choice. ( I also didn't really like any of the RRS designs when fitted to the FFRR. the FFRR ones look better imho. )
I ended up buying the RRS alloys from Scotland - they are on their way to Norway now |
