Home > Technical (L322) > Front prop shaft is fouling the cross member. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Front prop shaft is fouling the cross member, it is a shiny band right above the bar in line with the bell housing/ torque converter housing. There was a good gap when I looked. Anyone got any ideas why there may be contact? |
1st Nov 2015 2:51pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
If it's fouling the cross member then you have serious problems with the engine or gearbox mounts!
1st Nov 2015 3:36pm |
A photo or two sorry best I could do not as agile as I used to be
1st Nov 2015 4:37pm |
A picture is worth a thousand words, that has helped a lot.
1st Nov 2015 5:30pm |
There is no noise or jerking selecting D or R, in fact it is silky smooth compared to the excellent Toyota box I used to have and I thought that was good. 85K miles and still the original guess the drive shaft joint is ok.
1st Nov 2015 7:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Your gearbox sump looks damp as well, if it is oil I'd get a gearbox service done asap... Pete
1st Nov 2015 9:05pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1752 |
Unnecessary quote removed
1st Nov 2015 10:35pm |
Spoke to Land Rover not turned down yet, although not looking like a free of charge upgrade as they call it.
5th Nov 2015 2:46pm |
Is it giving you a problem?
5th Nov 2015 2:58pm |
