Home > Off Topic > One for the AudioPhiles or AV buffs |
Is there any speaker out there that is about 1" tall and utpo 10" long that would be perfectly suited to being a centre speaker?
26th Oct 2015 4:14pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I can't think of any speaker that small - you'd need an array of 1" speakers
26th Oct 2015 5:47pm |
Thing is if I block it with something taller then it would need to be quite shallow to fit in the gap between the stand and the display so back to square one due to space.
26th Oct 2015 6:23pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I don't know if this would help but here goes.
26th Oct 2015 8:01pm |
It sounds(!) like it has its own built in psu and amp
26th Oct 2015 11:30pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Can't the TV be lifted up? it might be worth trying to do, especially if you have a good centre speaker at the moment, as I fear that you maybe a bit with the sound performance of a 1" high speaker. For starters it will be a very tinny sound, as there is no way it will move any air.
27th Oct 2015 12:07am |
The centre speaker is purely speech but has two decent sized drivers in it
27th Oct 2015 12:21am |
FYI the system I have is the slightly older version of this with 2 additional side speakers 👍
27th Oct 2015 12:24am |
You went for the whole package then I just got the amp and added different speakers to mine, I think my centre speaker is 2 x 5" Eltax, it has bass reflex ports which add to the sound nicely, Kef floor standing speakers front, Eltax 4 way mids and 2 way rears. I did bag some 5 way Eltax for the fronts, but I never quite got round to changing them...... one day, I might try the bi pole rears that I got at the same time!
27th Oct 2015 1:05am |
take a front rear pic and then we might come up with a few suggestions
27th Oct 2015 1:28am |
I've got some Bose kit, but the VCS10 is still just over 3" high. |
27th Oct 2015 8:30am |
Speakers are the same spec
27th Oct 2015 8:33am |
Checking Sony.co.uk instead of .com I've found these now
27th Oct 2015 8:47am |
one of my problems Unless i buy it, pull the gubbins out and run decent cable to the speakers in some way.
27th Oct 2015 11:46am |
