Home > In Car Electronics (L322) > CD's only play through left hand speakers.
belldarr
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi - I am hoping that someone has had this before and resolved it, I have used the search function but didn't see any posts that had this issue.
I have the early set-up in my 2004 Vogue, non touch-screen version. My problem is that when I play CD's the sound only comes through the left hand/passenger side speakers. The radio is fine and plays through both sides of the car as normal. I have gone into the settings and made sure the fader and balance are all ok, I have switched the settings to play only on the right hand side and no sound at all.
I have looked at the amp in the boot and unplugged the connectors and re-seated them (just in case there is any bad connections) and it's all bone dry in there.
Any ideas what to look at next? It hasn't got the HK set up and appears to be all original.
Darren
Post #354268 26th Oct 2015 8:39pm
If it's just the CD player I'd hazard a guess it's the plug in the back of it not making full contact, it's a pain to get out, you have to remove the glove box... Pete
Post #354271 26th Oct 2015 9:49pm
belldarr
Hi Pete, thanks for the reply - yes sounds like I should have a crack at getting the cd changer out and have a look.
Darren.
Post #354276 26th Oct 2015 10:33pm
miggit
Hi Darren, if your a lucky Censored it will be a wire, here's a link to an earlier thread that lists all the 10 pin plug wires and their functions, ( it's a way down but I got there in the end Thumbs Up )
http://www.fullfatrr.com/forum/topic26808.html
Are you near to MK? Cos I've got a fully working CD changer, that's gathering dust if you'd like something to test the car with Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #354284 26th Oct 2015 11:42pm
belldarr
Hi Paul,
I won't be so lucky - I was convinced it was the amp and have been looking for one on ebay, but niggling doubt has crept in as all the other modes play through all the speakers. So I am thinking CD changer is duff or the connector is furred up.
If I need to borrow your known good unit I will give you a shout, thank you very much for the offer - I am just down the A5 in Edlesborough Smile
Regards
Darren
Post #354372 27th Oct 2015 5:34pm
If you have to buy something new for it, think about the Android unit, replaces all the old antiquated stuff in there and is far easier to use....
Plus if most of the original bits work it won't cost anything to change... Thumbs Up Pete
Post #354375 27th Oct 2015 5:50pm
