Home > Technical (L322) > Surprise- that went quite well |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
You will be in tears by the end of the day !! The small pipe at the back was a pig of a job as was replacing the oil separator , the one shaped like a cone which is necessary if you are doing a proper overhaul of the system. |
26th Oct 2015 8:38am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
You can clean out and re-use the OSV (cone shaped item) - mine was not too bad. WD40, petrol, have been used by various people to clean it.
26th Oct 2015 10:12am |
Reecy Member Since: 02 May 2015 Location: Southport, Lancashire Posts: 56 |
Job finished---- and yes the two lower pipes were awful
1st Nov 2015 7:05pm |
Well done.
1st Nov 2015 9:53pm |
