![]() | Home > Maintenance & Mods (L322) > Td6 front brake pads |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1434 ![]() ![]() |
IIRC: Both calipers just push back. Fronts are definitely push back. Wind back pistons are generally for handbrake activated movement, but cause the handbrake is on a separate drum, then the pads are just push back. Worth giving everything a wee clean, especially the calliper sliding pins if the pads didn't come with any new ones.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
Recently did my disco which has a similar set up with a 2 pot trw caliper.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Done my discs and pads all round, but only single piston calipers on front and rear.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8445 ![]() ![]() ![]() |
These were mine after 135,000 miles... V8 and TD6 have the same brakes...
Fitted Mintex and mine sounded like a London bus stopping every time I pressed the brake. After 2 weeks of hell they were swapped for genuine LR pads and the squealing stopped |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
Just had mintex put on mine (front only) and no squeaking and work very well. |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
I have just been looking at Euro car parts and they are listing brembo pads for my car will any of the pads make a difference over genuine Land Rover ones or should I just fit genuine |
I'd just fit genuine, get them from Dan at Duckworths, site sponsor, too many threads on here about noisy pads that weren't genuine... Pete
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
is there a chance to get ATE Brakes in the UK? They have good quality! |
