![]() | Home > Maintenance & Mods (L405) > Wheel Hub & Wheel Nut Problem Today |
sherman Member Since: 23 Aug 2015 Location: L'Isle Jourdain Posts: 71 ![]() ![]() ![]() |
Ive had 4 sets of wheels powder coated in the past, and currently waiting for the latest to come back for fitting to my FFRR. I have had no problems with them at all, but as a member of the MX5 owners site, I know quite a few peeps who had trouble with swelling paint, usually caused by the use of solvents, apparently.
Having just woffled on to you about swelling powder-coated wheels, Ive also found this on the Disco site, which is a similar problem I had on the FD's old mini cooper wheels..........so this may be of more use to you than my previous post.
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Sorry if I confused matters, Im not commenting about the condition of the wheels, they are fine, its a comment about the wheel nuts being faulty and the hub being damaged by LR during recent suspension / drivetrain repairs?
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I did have my LR dealer report some swollen wheel nuts on my L322 when it was serviced a year or two back and I agreed to have the swollen ones replaced to avoid the problem of fitting a socket to them which you describe.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Swollen nuts on the 322 was / is, a common problem. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Iirc the hub was damaged when they played with the front diff, probably used some sort of persuader to get the splined shaft out of the hub, which is why it is flared and the new wheel won't go on. LR had done this to my 3.6 l322 and I had to have the hub changed to fix it. There is nothing that can't be fixed with a hammer😜😜
Just the info I was looking for, thank you very much |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
Just on the subject of the swollen nuts, LR should change these for you under warranty on a 2013 car, at least the non-locking ones. That's what happened with my 322, luckily I spotted it just before the warranty expired.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Swollen nuts is a long standing issue.
Its crap design that causes the issue, they aren't really upto the job of being taken on and off a few times in their lives. The outter steel covering dowsn't help matter or that the alloy used for them is too soft as a sacrificial metal.
