Home > Maintenance & Mods (L322) > no hot air middle vents |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35269 |
have you turned the dial to red... ... - .- -.
19th Oct 2015 11:41am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Have you turned the dial in between the vents to 'red' as 'blue' is obviously cold air and red hot. |
19th Oct 2015 11:42am |
tevista Member Since: 20 Sep 2014 Location: paisley Posts: 16 |
yeh , hot top and bottom but cold from centre . |
19th Oct 2015 11:47am |
could be the blend motor flaps sticking....do they work when in auto mode.. ... - .- -.
19th Oct 2015 11:58am |
good point , try that at 5 when i head home . |
19th Oct 2015 12:11pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I have same problem. No warm air comes out, only way to get warm air out is to press the direction button below to manual send air through the middle vents. Won't send warm air out at all on auto. It will send out cold air when the dial above is showing blue but no warm air on red. |
19th Oct 2015 10:33pm |
Yep Lad , same fix as yours . Another gremlin creeps in . |
20th Oct 2015 6:41am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Wonder if this is a seasonal thing I have just had the same problem.
20th Oct 2015 10:46am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
People - these are not gremlins or quirks.
20th Oct 2015 10:49am |
