Home > Wheels & Tyres > Uneven tyre wear - can a wheel bearing cause it? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
The rear tyres on mine went like that, the rear camber is supposed to be set to around -2 deg, I readjusted mine to + 1 deg and the wear is now even, the turn in is now much better as well.....
19th Oct 2015 8:52am |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
FWIW I had a rumble from one side recently. Was convinced it must be a wheel bearing on its way out. Took it into the garage and the tyre was like yours. Put a new one on and the rumble has gone.
19th Oct 2015 9:24am |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Mine did exactly the same as this and it turned out to be the rear suspension bushes |
20th Oct 2015 8:38am |
Obviously more than one reason does this then as my bushes were all new just before the tyres, and it had a four wheel laser alignment and was adjusted to factory spec...
20th Oct 2015 10:06am |
