Home > Technical (L322) > Transfer box leak |
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 |
I found the topic about rrphil, opening the transfer case.
17th Oct 2015 3:48pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
Have a good trace first, before opening the box. I had mine re sealed twice, before I found that it was leaking from the o ring on the high low shift sensor on top of the box. Much easier and cheaper to fix. Was really difficult to trace as it wasn't leaking much. Give it a good clean then see where it's coming from There is nothing that can't be fixed with a hammer😜😜
17th Oct 2015 4:57pm |
Ok thanks!
17th Oct 2015 5:02pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I had this problem and it turned out to be a crack in the casing! I had the crack weled by a specialist but it didn't cure it as he didn't put it back together properly, in the end
18th Oct 2015 8:34am |
The underside of my disco one is a bit moist, but it's not getting fixed until it starts dripping, has been bone dry up until recently! There is nothing that can't be fixed with a hammer😜😜
18th Oct 2015 8:38am |
