Home > Technical (L322) > A/C button flashing?
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
Today when i started the car i noticed that the a/c light on the climate controll panel flashed. First it flashed a couple of times then it went out completely a couple of seconds then it started flashing again. At first when i tried to press the button nothing happend but after a couple of pushes i was able to turn the flashing of. Turned it on again and it flashed a couple of more times then it started to behave as normal and i didnt have any problems with it.
Have never seen this before, any ideas? Temperature was around 10 celsius at the time. Car is a 2003 petrol
Cheers! Very Happy L322 Vogue 2003
Post #352417 15th Oct 2015 7:10pm
Starberg
Wow, am i really the first on this one? Congratz to me then i guess....not
Could it have something to do with the ac magnetic clutch? L322 Vogue 2003
Post #352492 16th Oct 2015 8:32am
possibly low gas? ... - .- -.
Post #352496 16th Oct 2015 8:55am
Starberg
Doubt it.. Had the system pressure checked and refilled with new gas just before the summer at a very good local indy and they said everything looked tiptop!
I should also mention that i changed the climate panel to a brand new facelift version (the one with silverknobs) the other day since my old one was broke but the only differance between the old and new panel is that the A/C and the "PROG" button has swapped places.. L322 Vogue 2003
Post #352550 16th Oct 2015 12:44pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
It may be worth trying your old panel in again incase your new panel is in some way faulty. Ive never heard of a flashing ac button and I spent several months researching ac problems when my system failed!
Post #352571 16th Oct 2015 3:13pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I seem to remember many moons ago reading that the A/C light would flash if the system could not reach the temperature set on the dial i.e sun room open, A/C on low.
Could this be your problem?
Post #352670 17th Oct 2015 9:23am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
to MillarJ90s point - it could be an internal cabin temp sensor failed so the unit "thinks" it can't reach temperature?
probably needs to go on diags to get fault codes read. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #352673 17th Oct 2015 9:40am
Starberg
Hmm probably has something to do with the new climate panel since it started after i did the change Big Cry
Gonna do a diags with my rsw and see if anything comes up, maybe gonna have to send it back to uk.. L322 Vogue 2003
Post #352676 17th Oct 2015 10:02am
