Home > In Car Electronics (L322) > TV Tuner Confusion |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I did the same on mine. Taking the old one out looks simple, but it'll take about an hour as you pretty much have to remove everything in that eletronics stack to get the bracket that hold the TV tuner out. You'll also find if you can get an IID tool, you can change the TV tuner settings to Digital only, Hybrid or Analogue (which yours well already be set to). I found when i did mine, before i told the car it was a Hybrid module, it worked but didn't display the channel names properly. Changing to Hybrid makes all the freeview channel names show up properly. And changing the setting to digital only, makes it acquire the channels much more quickly (presumably it just ignores the analogue band, rather than sit there searching it for nothing) |
15th Oct 2015 8:12pm |
If anyone thinks £350 is steep for a to module. I've just been looking into upgrading my mates Audi. Used Audi modules are around the £800 mark!
3rd Nov 2015 7:46am |
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 |
I've just bought and fitted one from these guys.
11th Nov 2015 9:14pm |
