Home > Technical (L322) > Engine system fault
viper
Engine system fault
Ive had a read on the various section and I'm seeing split turbo hose, but as anyone got anything to add from experience.
On a long run today , stopped for about an hour
and when I got going again I got the engine system fault message and car went into limp mode, message went away but car stayed in limp, engine turned off and then back on again and everything was back to normal, power seems as norm , no visable smoke. Only thing I can say is that the engine noise or the turbo noise on the right side sounds a bit noiser than normal when accelerating , but might be my imagination .
battery is good and strong , any ideas ? would a fault reader give a better idea ?
Post #352280 14th Oct 2015 7:34pm
Take the top hoses off, first and easiest place to start. Might not get a lot of smoke, and the fault resets when you turn it off....
They come off with a screwdriver! Check the passenger side one under the webbing. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #352282 14th Oct 2015 7:40pm
DSCOOPS
England 2006 Range Rover Vogue SE TDV8 Barolo Black
Viper what is the mileage? My experience with this unfortunately is I have a 112000 mile tdv8 with a sticky egr valve that pings up the engine system fault during hard acceleration. This is cleared if you turn off and on the ignition. I haven't checked the turbo hoses but just yesterday had a mobile chappie put his diagnostic machine on which showed one valve open at 12% which was imbalanced to the other. Like northern says check the pipes first as it's well cheaper. Do you get a groaning noise on the right?
Post #352285 14th Oct 2015 7:58pm
viper
mileage is 83k, cant say I can hear a groaning noise. I will get the hoses checked first, how does one check for a sticking valve
Post #352288 14th Oct 2015 8:07pm
With a diagnostic tool, it can measure the amount that the valves are open and see if one sticks open slightly.
10 min job to check the hose on the drive, honestly, no skills required. If you can undo a couple of jubilee clips then you are sorted Thumbs Up nothing to drain or move out of the way really.
http://www.fullfatrr.com/forum/topic26843.html
Fixed mine on a caravan site in Dover with a screwdriver and some tape. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #352289 14th Oct 2015 8:15pm
DSCOOPS
+1 Thumbs Up
Post #352291 14th Oct 2015 8:21pm
viper
that's great northernmonkeyjones , thanks very much, hopefully that will be my trouble, I'm guesing the left hand hose is just as easy as your split right one?
Post #352293 14th Oct 2015 8:32pm
Thumbs Up yep. 5 mins. There is nothing that can't be fixed with a hammer😜😜
Post #352294 14th Oct 2015 8:37pm
viper
50mm split in driver side hose , underneath right near the front jubilee clip , clue was some blown oil residue on the coolant expansion bottle. Looking at about 40 beer tokens for a genuine one
thanks guys Thumbs Up
Post #352717 17th Oct 2015 12:48pm
DSCOOPS
Post #352750 17th Oct 2015 5:34pm
Post #352751 17th Oct 2015 5:41pm
ebajema
There is a post about a silicone house set on here from a UK manufacturer. Maybe worth investing in the house set that is supposedly much sturdier and more durable.
http://www.fullfatrr.com/forum/topic32550....icon+hoses MY 2010 5.0 SC Galway green and sand interior!!
Post #352803 18th Oct 2015 4:31am
