![]() | Home > Technical (L322) > Suspension had dropped |
You are probably losing air from a cracked air bad that has now sealed itself in a fold . Get some soapy water and inspect each air spring at all different heights but my money is on front offside .
DSCOOPS Member Since: 15 Jul 2015 Location: Staffs Posts: 26 ![]() ![]() ![]() |
+1 did the same thing on mine. Filled sprayer bottle up with soapy water and found the fault. |
Bobby Member Since: 02 Oct 2015 Location: London Posts: 26 ![]() ![]() ![]() |
Thanks will give that a go.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Your symptoms would indicate a leak, what usually happens is you get a small leak but don't know because the pump can keep up with the air leaving the system, the first you know about it is when the pump gives up as the poor thing has been working flat out for weeks on end.... this is easily done on the later ones where you can't really hear the pump so don't realise that it has been working flat out...
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Bobby, as Pete says above but......... Yours is a 4.4TDV8 i presume? In which case the front macpherson strut will be electronic and different to the early cars Pete is referring too sir...
Thanks for all your help, much appreciated.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
in normal height the bag could be hidng the hole and sealing it, in
Thank you for your input, will try this tonight and see what happens.
Hi
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
earlier this year we were away on Holiday, came out one morning and the Ff was 'on the floor'. On starting, no warnings or faults and returned to normal height. Over the next couple of weeks, intermittently it dropped down. Thought possibly an air leak, so left it overnight in off road height, and din't drop at all. Then invested in an IID tool, fault code 'right rear suspension sensor voltage out of limits'. Replaced the sensor, re-calibrated the suspension and all has been fine ever since. The old sensor had developed a 'flat spot' - don't know if this is relevant to you, but may be worth checking for fault codes? |
Thanks for the input.
davidsmith1307 Member Since: 05 Mar 2015 Location: Hull Posts: 52 ![]() ![]() |
Thanks everyone, A faulty sensor and i had the 4 wheels re-aligned as the steering was out abit
