Home > Maintenance & Mods (L322) > Artic MONKEY Car Jackers - FFRR
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Having not long returned back in UK I decided to put new tyre's on one of the FFRR ready for her winter trips
I have attached some pictures that I took today which had me worried.
As you can see in the pictures it looks like a trolley jack has pierced the metal rear wish bones - but looking closely EACH SIDE rear wish bones have marks in different places - they are not consistent on either side.
It now appears that my tyre place did not do these - they are manufacturing piercing into the metal - so if you see these on your FFRR they are correct - God knows why !
I can only think they are their to drain out water - but I can't understand why they are not evenly spaced or evenly cut out ?? - they do go into the metal casing - its like someone had hit them with a cold chisel.
I have seen a few garages - NOT LR Dealers in anyway they know what they are doing - a few other 3rd parties garages & tyre places using trolley jacks on RR - so beware - and know whats under your car - Knowledge is king ( hence that why we have this site ) Bow down
Does anyone know why ? - anyone noticed these before.
Post #352106 13th Oct 2015 7:21pm
What the hell trolley Jack is doing that as they are very thick pieces of metal. Maybe it's a revision. It I'm sure mine doesn't have them... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #352137 13th Oct 2015 10:40pm
johnboyairey
They appear to be just water drain holes. A few years ago, many cars had the voids in subframes, factory filled with expanded foam, to cut down on road noise. This worked, however, the condensation from typical overnights, and road splash from driving, meant that subframes rotted out from inside. So I guess the water that enters, might run down, will have many chances to escape. Around that bolt shaping. And a trolley jack would not dent or pierce such thick steel.
Post #352144 13th Oct 2015 11:03pm
miggit
I suspect that they are there to relive stress caused when the lower wish bone is formed Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #352149 13th Oct 2015 11:30pm
EmiratesA380
Hi miggit
I can see where you are coming from - but why are they all different angles / cuts - its as if a Chisel has been there ?
Have you looked on yours ?
I see kingpleb - says he does not have them ?
Sounds like someone has got a trolley jack under mine at some time then from what I am reading - as no way should they be lifted by this method.
Post #352164 14th Oct 2015 7:54am
It would need to be one heck of a trolley jack to pierce the metal there as it is heavy duty steel plate
Post #352168 14th Oct 2015 7:57am
just looked at mine [cold out there brrrrr] and i have them as well... ... - .- -.
Post #352170 14th Oct 2015 8:03am
EmiratesA380
Hi 47p2
I have looked at these dents/cuts on mine in my work pit in barn - they are only approx 1.4 - 2mm thickness steel plate ( what hardness steel plate I have no idea ) - I think you think they are thicker !!!, when you have approx 1.6 tonnes of FFRR pushing down on one piece - then I am sure something can go into them - dent them.
Another question - is it worth spraying Wax Oil into these ( Wax Oil with 20% white spirit added Thinness ) to cure inside - as someone suggests water channels ?
1. Why are they there ?
3. Why are they all different lengths ( its as if they have been done by hand or Monkey Jack )
Post #352176 14th Oct 2015 8:34am
Possibly put there to drain water after going through deep water or maybe something to do with the manufacturing process where a mechanical arm would pick the part up and reposition it accurately for the next process.
2mm is a hefty chunk of steel which can easily support the weight of the FFRR on a trolley jack although the angle these sit at does not really allow for this to work to our advantage and I would never jack up a FFRR on this part. I don't see a problem in coating the inside with Waxoyl or similar so if that's your thing go for it Thumbs Up
Post #352181 14th Oct 2015 8:52am
the wishbones are hollow so these holes must be drain holes... ... - .- -.
Post #352184 14th Oct 2015 9:01am
miggit
I haven't looked at mine yet, Shocked face, bothered? But it seems that they are present on later ffrr's...... could this be a half assed attempt at lightening the car? Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #352219 14th Oct 2015 1:14pm
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
 Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #352223 14th Oct 2015 1:24pm
That's it...Speed holes where wackyjim hides his stash Laughing Laughing Laughing
Post #352243 14th Oct 2015 4:12pm
