Home > Maintenance & Mods (L322) > Headlights
markcartlidge
Headlights
Hi All,
Looking for some advice about headlights on my 02 4.4V8 Vogue. I have had problems with the NS dipped beam not starting properly. I sometimes vercome the problem by switching on/off.
However driving home last night I thought the dipped lights seemd very low as per the attached. I would expect them to 5 to 10degress higher and presume it is the self levelling system which has given up?
Any suggestion greatfully accepted.
dipped
main beam
Post #351993 13th Oct 2015 10:02am
AFAIK they don't self level, the air suspension does that so they don't have to...
They are Bi-Zenons so use the same bulb for low and high beam with a flap that moves to expose more light (the high beam bulb is for a flash and to fill in the time it takes for the flap to move)
You can adjust them, there are two adjustments on the top of the unit, one for side to side, one for up and down...
Any MOT garage can set them up correctly if you can't do it yourself... Pete
Post #352007 13th Oct 2015 11:10am
http://www.fullfatrr.com/forum/topic33837.html
Post #352008 13th Oct 2015 11:11am
