Home > Technical (L322) > Diff Recall - Can someone just confirm mine is unnafected ?
Avi
2006 Range Rover Vogue Td6 Alveston Red
I've searched and searched, and believe that mine has the upgraded diff as it has the 2006 facelift.
It says they introduced it with the Jag Engines, but the TD6 wasn;t changed. I assume the did all diffs though ?
It's a July 2005 TD6 with the 06 facelift/reverse cam/touch screen , can someone confirm i don't need to go and check please and get all wet Very Happy
Thanks
Andy Smile
Post #35176 8th Nov 2010 11:53am
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Best thing is to check with your servicing dealer. When i booked my service this year they mention the diff modifacation to me. They then done whilst car was in for service. no problem at all.
Post #35178 8th Nov 2010 12:03pm
Fox
Best to check with a dealer, but when I got my 55 plate (Nov 2005) it was the 06 model year and they told me the diff spec had been changed so they didn't suffer the same failures as the old ones.
Post #35179 8th Nov 2010 12:06pm
Avi
Thanks Richard
That's what i'm assuming mine will be like as it's an 06MY . I may get wet later and have a crawl underneath.
Post #35191 8th Nov 2010 12:40pm
if you are lucky enough to have service history invoices it should be marked on that...mines a june 2005 and i had the diff done in july 2007... ... - .- -.
Post #35200 8th Nov 2010 12:54pm
Avi
I don;t have them unfortunately. It's been serviced at the same dealer since new, so i'll probably ring them.
Is yours the older style, just before the facelift ?
Post #35204 8th Nov 2010 1:01pm
Fox
What year model does your chassis number show Scarey?
(it's the number before the A in 10th or 11th place on the VIN number)
Post #35205 8th Nov 2010 1:01pm
@ avi..mines the middle one with the old square front grill ,no dip in the front bumper but with a touch screen nav unit.
@fox..eight letters then 35 then letter a... ... - .- -.
Post #35208 8th Nov 2010 1:15pm
Fox
That makes sense then, it's a 5. So 2005 model. Diff was supposedly changed on the 6.
Just for info, the 3 means RHD auto. Thumbs Up
Post #35209 8th Nov 2010 1:18pm
is the month of manufacturer on the vin fox? ... - .- -.
Post #35210 8th Nov 2010 1:26pm
Fox
Not as such, but you could see where in the sequence it came with the last 5 or 6 digits after that letter A. ie, if it was earlier or later than another 5 model.
I'm sure someone (Gaydon maybe?) would have records for which sequences of chassis numbers were made when. They could probably even tell you the day.
Older LR owners can contact Gaydon (I think it's them) and find out when they were made to help build a case for free road tax (pre 72) where it's made in 72, but registered in 73. So exact records are kept and accessible.
Post #35212 8th Nov 2010 1:35pm
Thumbs Up thanks. ... - .- -.
Post #35213 8th Nov 2010 1:38pm
Avi
Mine's a 36 so that confirms it's a 2006MY, just in case someone had facelifted it and worked out how to fit reversing cameras Laughing . I believe there's some 2006 Models registered as early as May 2005. Mine was registered in July.
Post #35218 8th Nov 2010 1:57pm
