![]() | Home > In Car Electronics (L322) > Towbar ECU mapping. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
i believe that an iidtool will do this job, worth investing in one.. ... - .- -.
PeteH Member Since: 01 Aug 2015 Location: Manchester Posts: 10 ![]() ![]() ![]() |
Thanks.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
As ever Stan is right, I did mine with the IIDTool although it gives lots of options I just set mine to 13 pin and it seems to work fine although I have 7 N and S Geoff |
Thanks. That's great....
You're more than welcome to use mine if the BT version will do any car and you don't mind a quick jaunt down the M61 to Chorley if you don't get another offer sooner. I won't be able to help 'till Wednesday though. Geoff |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
The regular IID is mapped to a a single car - it can support multiple, but you will need an additional licence.
[quote="supershuttle"]You're more than welcome to use mine if the BT version will do any car and you don't mind a quick jaunt down the M61 to Chorley if you don't get another offer sooner. I won't be able to help 'till Wednesday though.[/quot
https://www.gap-diagnostic.com/products/iidtool/
Thanks for your help , guys... |
Just looked back - Dan was doing the VIN addition for £60 in May - not sure if that's still the case |
