Home > Technical (L322) > 4.2SC Strange Noise
dan_uk_1984
4.2SC Strange Noise
I have a high mileage (165,000) 4.2SC that has an odd reverberating noise around 1900-2200rpm. It does it in every gear regardless of speed so I've partially ruled out drivetrain.
I wondered if at 165K it's feasible for the CATs to be breaking down or be partially blocked giving me this reverberating/humming noise. It's very loud, louder than the engine, but almost seems louder inside the car than out. The noise goes away if I put my foot down or back off, typically the throttle load I guess is about 25%
I've tried recording it, but my phone doesn't pick it up at all so I know this isn't going to be an easy one to diagnose - just wondered if anyone else had experienced similar?
Dan
Sheep
Post #350438 3rd Oct 2015 10:30am
Does it do it if you sit still and rev it to those revs, and does going up or down a hill make any difference?? Pete
Post #350545 3rd Oct 2015 11:34pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Process of elimination............., engine / transmission mount?
does the vibration occur stationary during torque stall ? don't over heat the trans! might eliminate transmission Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #350558 4th Oct 2015 7:37am
Loose heat shield somewhere? As said above, can you replicate it stationary?
Get underneath with a rubber hammer and bang at stuff to see if there is anything loose. There is nothing that can't be fixed with a hammer😜😜
Post #350564 4th Oct 2015 8:54am
dan_uk_1984
Thanks for the replies:
It only does it whilst driving and under load, worse when light throttle is causing the engine to labour slightly.
The noise is so deep and boomy I don't think it could be an exhaust shield as these tend to be a tinny rattle. but I will add them to the things to check. Thumbs Up
I hadn't considered engine/gearbox mount, thanks.
Post #350724 5th Oct 2015 12:34pm
dan_uk_1984
Well I found a second hand exhaust, cats back so we'll see if this resolves the issue, worth a punt for £100 I thought.
Post #351678 11th Oct 2015 1:58pm
