![]() | Home > Technical (L322) > fault codes ? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
You have a scanner?
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
^----- +1 for what @RR_P38 said
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
there's a link in the wiki to a fault code site, might help.. ... - .- -.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Are you getting any symptoms?
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
hi thanks for the advice, yes the codes were reset and have come back. only getting black smoke when hard acceleration.
These are the ones:
took off the hoses to inspect but no splits on either, tightened up the jubilees and test drove but still smoking |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Did you pull back the webbing round the passenger side upper, it normally fails under the webbing. There is nothing that can't be fixed with a hammer😜😜
yes had a good look under the webbing couldn't see any splits, it only smokes from the drivers side exhaust ? |
