Home > Duckworth Parts > 2002 v8 4.4L Gearbox and Transmission parts
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi Dan
Looking to do transmission component fluid changes so need new gaskets, filters, sealing washers/O rings (or plugs if the washer/ring not separate item) - I am sure you know better than me the parts/ names required to stop the damn thing leaking when I put the new oil in Smile
Gearbox
Genuine LR/Filtran unit (LPW000030)
1 ‘O’ ring (TYX000100)
1 Gasket (TYF000110)
Sealing washer / O rings for
Transfer Box
Front Diff (Note mine had the diff recall done so not sure if that changes the part required)
Rear Diff
Many thanks Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #350332 2nd Oct 2015 2:25pm
duckworthparts
Site Sponsor
Afternoon
Gearbox
Genuine LR/Filtran unit (LPW000030) £28.50inc vat
1 ‘O’ ring (TYX000100) £0.59inc vat
1 Gasket (TYF000110) £15.36inc vat
Transfer Box IYF500010 x 2 £2.00inc vat
Front Diff
TYB000010 £5.15inc vat
TYP000220 £5.40inc vat
Rear Diff
RYX000020 £0.40inc vat
8510276 £4.20inc vat
Cheers
Dan You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #350333 2nd Oct 2015 3:07pm
johnboyairey
Buy yourself a cheap oil syringe from eBay, it will help you to inject the oil rather than trying to squeeze half a bottle out, and refill etc, also take care to read up on getting the correct level, ie when hot, etc, the syringe will also stop you getting burnt, only about a £5
When you drop the tray, clean the four magnets and rinse out tray with fuel etc. The torx bolts have a habit of being very tight, so plus gas! Em and use correct torx bit, as it's nearly the size down, which fits easily, but strips the head. Shocked and use genuine Mobil fluid, it's about £10 a bottle, - eBay again. I think it's lt71141 from memory. You will need about 7 litres, but might only drop and replace about 5l. Be sure to carefully check levels after a test drive. -fill to overflowing etc. Read up here.
Post #350343 2nd Oct 2015 4:40pm
SMUTT
Hi Dan
Thank you for the quote - just trying to ascertain correct sealing washers or sealant for the diffs - seems to conflicting info in Rave, microcat and some posts on here - got to get under the car and check
@johnboyairey - many thanks for the advice. As this is the first change and includes filter, I am going to get someone (Neil Smith in Cannock) to do it for me. Also I don't have a flat driveway, and unless a car is on a proper ramp, it takes me several times to get "comfortable" working under a car, and especially one with the engine running, basically I am a bit chicken as claustrophobia creeps in. The next change won't be so bad as it will not include filter, and at least I will see the plugs undone recently. Howard
Post #350523 3rd Oct 2015 7:58pm
SMUTT
Hi Dan
Paypal sent for
Gearbox
Many thanks
Howard Howard
Post #350754 5th Oct 2015 2:50pm
duckworthparts
Site Sponsor
received Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #350756 5th Oct 2015 3:04pm
SMUTT
Hi Dan
Can I also have price for Castrol BOT 26 FMB 1 (STC4861) (1 litre)
You can ship with other item to save postage.
Many thanks Howard
Post #350757 5th Oct 2015 3:23pm
duckworthparts
Site Sponsor
yes can pop with the other order
would be £13.00inc vat p/litre You can paypal direct using - www.paypal.me/duckworthparts
Post #350759 5th Oct 2015 3:30pm
SMUTT
Hi Dan
Great - payment sent - thank you very much Thumbs Up Howard
Post #350760 5th Oct 2015 3:42pm
SMUTT
Hi Dan
Arrived today - thank you very much.
Appears to be missing 1 Gasket (TYF000110) £15.36inc vat
Could you check your end? Or is it in a separate parcel?
Many thanks
Howard Howard
Post #351195 8th Oct 2015 10:22am
duckworthparts
Site Sponsor
Howard
sent it as a seperate parcel via royal mail, didn't have a box big enough to get the gasket in with the other parts Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #351197 8th Oct 2015 10:30am
SMUTT
Hi Dan
Thank you for that info. No problem. Thumbs Up
On checking there appears to be 2 bottles "Castrol BOT 26 FMB 1 (STC4861) (1 litre) " - instead of 1.
How do you wish it returned?
Thanks Howard
Post #351224 8th Oct 2015 12:33pm
