Home > Technical (L322) > Can the convenience close be done with the Fob?
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
As the title says or is it only done with key in door? Thanks.
Post #351141 8th Oct 2015 1:17am
if you mean windows up/down then yes it can be activated in the ccf with an iidtool.. ... - .- -.
Post #351157 8th Oct 2015 7:06am
I believe that everything you do with the key can be replicated with the remote sir... Some things need to be switched on using the CCF though Rolling Eyes Which needs to be accessed through the OBD port using a suitable device like the IID Tool Stan mentions above Thumbs Up
Post #351160 8th Oct 2015 7:15am
ebajema
It is easy to find out whether it is switched on. Open the windows, take the key out, get out and press and hold the lock button for some 2 seconds. It worked on my NAS 4.2 SC. I used the lazy or convenience unlock a lot to get rid of the hot air after it had been sitting in the sun. Hardly used the convenience closing but it did work.
Good luck Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #351166 8th Oct 2015 7:31am
doclees
Thanks folks, I thought there was a setting that I turned on through my iidtool. I will recheck it. Maybe I didn't save the setting. At this time its not working. The RAVE only mentioned the key in door method that I could find. Also my driver's door lock is not work too and wasn't sure if that was causing a problem. It all goes down fine.
Update: yup just didn't save the settings.
Post #351230 8th Oct 2015 1:09pm
