Home > Technical (L322) > Suspension Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
i'd be tempted to disconnect the battery , do the left to right steering lock and see where that gets you.. ... - .- -.
7th Oct 2015 6:07pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Thanks Stan I did the left right lock but didn't think about disconnecting the battery. Would that clear random codes? |
7th Oct 2015 6:13pm |
it wont get rid of any faults codes but i suspect the battery might have been disconnected when they did the hoses but the steering parameters were not set..
7th Oct 2015 6:18pm |
Thanks will get onto that in the morning worth a go to save a journey back to the dealers! Did I also read that a faulty ABS sensor gives the same message or would that come on when driving?? |
7th Oct 2015 6:22pm |
that could be the cause and they could have damaged it whilst doing the hoses.... ... - .- -.
7th Oct 2015 6:30pm |
Battery pull didn't fix it unfortunately so it was back to the dealer!! 10 minutes later after a code read they realised they hadn't plugged the height sensor it properly so that sorted it. Good news that it wasn't a big bill! |
8th Oct 2015 1:18pm |
thats a relief then ... - .- -.
8th Oct 2015 1:46pm |
Poor show that a main dealer can miss something as important, especially after doing a 'health check'...WTF |
8th Oct 2015 2:46pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Er ... re-read your statement Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
8th Oct 2015 2:50pm |
It is pretty shocking and when I told them it must have been something they had done they didn't seem to be too believing!! What's worse is when the guy who did the health check flagged the warning to the service manager he apparently just said to leave it it's fine as it goes off again!! Gave me a nice cup of coffee though!! |
8th Oct 2015 3:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8285 |
What I can't understand is why they unplugged the height sensor when doing brake pipes, it's nowhere near and not connected to anything they would have to remove to do the job... Pete
8th Oct 2015 3:05pm |
Who knows unless it was a bit loose already and putting it on the ramp just disconnected it or they knocked it when doing the health check! |
8th Oct 2015 4:08pm |
I've read, re-read and re-re-read and still don't see what's wrong with it |
8th Oct 2015 4:21pm |
I've read it a few times and nor do I...
8th Oct 2015 4:50pm |
