Home > Maintenance & Mods (L322) > RSE Panel cover wont close
sherman
France 2007 Range Rover Vogue SE TDV8 Java Black
Morning all
Anybody ever had the RSE cover refusing to close? When you push it down, it just does its clever slow and graceful opening thing..........Should I be looking at the spring? Has anyone ever taken the cover off without damaging it?
If I cant fix it, Im gonna have to jury-rig some sort of pressure clip in the base that it can clip over - not an ideal solution...
Thanks for any ideas 2007 TDV8 VSE Java Black
1994 MX5 1.8s softtop customised VW Diamond Black SOLD
1995 Mini Cooper 1.3SPI
1974 MasseyFerguson145 with loader
1968 McCormick International (under restoration)
Post #350571 4th Oct 2015 8:53am
rse cover?
any pics.. ... - .- -.
Post #350596 4th Oct 2015 12:11pm
sherman
OOPs sorry....many apologies.....
RSE cover is the Rear Screen Entertainment cover.....my bad, Id been reading other posts which called it that, and just copied.....Its the lil plastic door that flips up and down, covering the Aux sockets for the Headrest screens.
Post #350597 4th Oct 2015 12:23pm
ah, i know now.. Thumbs Up
mines the same but it closes with click, maybe a catch/bit of plastic has broken off.. ... - .- -.
Post #350598 4th Oct 2015 12:26pm
sherman
Ahhhh, good thinking Stan.....I'd assumed it was a spring problem, not a catch problem...Ill get a torch on the job
Many thanks 2007 TDV8 VSE Java Black
Post #350599 4th Oct 2015 12:32pm
just looked at mine and i cant see a catch tbh, so i'm not sure how this lid works.. Confused ... - .- -.
Post #350623 4th Oct 2015 5:21pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
This cover is very very loose on my ff, you lift it, it stays up, close it there is no damping of any sort or latching.
It feels like hinges etc have broken Sad Can the cover mechanism be accessed?.
Post #350697 5th Oct 2015 9:17am
sherman
Hmmm, sounds like the spring has broken on yours, buddy..........When I look at the back of mine, I can see the end of a fine spring sticking up......I cant see any catch on it, so Im now thinking that the spring is supposed to hold it closed, so we have a similar problem.
Let me know if you manage to dismantle it, I wont get chance to look at it for a few days, but Ill let you know if I have any success.
And Stan....?...best treat yours carefully.......it looks like these things are not designed to be operated by small persons in the back seat!! 2007 TDV8 VSE Java Black
Post #350739 5th Oct 2015 1:31pm
