Home > Maintenance & Mods (L322) > squeak in rear end
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
squeak in rear end
Hi all I am stumped as to what is squeaking in the rear end. It sounds like I have dirty old leaf springs. I have sprayed lube in all the joints that look like they move and some that dont. But still no good.
please help.
cheers 02 l322 4.4 HSE
Sitting on 20's
All in Buckingham blue
Post #349895 29th Sep 2015 8:52am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
It may be the upper rose joint on the suspension, I think these fail and sound like an old pram. it's on my "tuit" list.
EDIT: it's on the hub end. from the Wiki: http://www.fullfatrr.com/forum/topic27263.html
I'm sure someone more knowledgeable will be along soon.
Thumbs Up Formerly happymadison1978
Post #349897 29th Sep 2015 8:56am
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Yes the rose joints.
The reason that spraying lube does not help is because the joints have a rubber cover and you cannot get the lube in. Time to replace them as per the Wiki.
One word of advise - even if you think you may get away with using threaded bar instead of the push pull tool per the Wiki. I certainly didn't!!
I have since used the tool for lots of other jobs as it saves on having to take something off the car and put in the press.
Post #349924 29th Sep 2015 1:12pm
Yep, what they said... don't buy cheap ones, genuine ones from Dan are less than �40 each and it's worth getting new bolts, nuts and washers, Also worth getting the suspension set up afterwards as the bolts control the rear camber... Pete
Post #349990 29th Sep 2015 7:59pm
marky777
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Bonatti Grey
Just done the rear o/s lower rose joint on mine 1 week ago. The noise was so annoying. Get it done at an indy, MD cost me �275 and the part was only �38.50
Shocked Shocked
Post #349995 29th Sep 2015 8:27pm
Blimey... did all four of mine in about two hours... must have been a very hard to remove bolt..... Pete
Post #349996 29th Sep 2015 8:32pm
marshy
Thanks gents will sort it out soon 02 l322 4.4 HSE
Sitting on 20's
Post #349997 29th Sep 2015 8:33pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Yep sounds like a rose bush. Mine was squeaking for a while, it sometimes sounds like an old spring mattress. Quite a cheap job from an independent if you don't want to do it yourself. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #350604 4th Oct 2015 2:02pm
CEEGEE
Mine seems to have developed this "squeaky pram syndrome", but;
a) definitely seems to be at the front
b) it doesn't do it every time I go out, but when it does, it's pretty loud - I was shocked by how loud when I put the window down
c) I cant get it to do it by trying to rock the car
d) it seems much worse over bumps/undulations when going down hill rather than up hill
e) seems worse if steering left
Tried my Indi once to cure it, with no joy - when I tried to tell him about this thread he thought it couldn't be the same problem, because the noise was coming from the front.
Any thoughts?
Thanks
Post #353424 21st Oct 2015 9:18am
I went over the whole front suspension on mine as I'd have put money on it being the front but it turned out to be the rear hub joints... As the front wheel goes over a bump the rear moves as well, you feel the bump from the front and then it squeaks so it appears to be the front...
It could, of course, be the front, the drop links have been known to squeak but I bet it's the rear....
I could get mine to squeak while stationary sometimes but mostly it wouldn't play ball...
Your indie should be able to check the rear joints easy enough, pry bar on the top one, let the wheels hang and pry bar on the bottom one... Thumbs Up Pete
Post #353450 21st Oct 2015 11:46am
CEEGEE
Okay, thanks - we'll see what he says.
So, there is nothing it can be at the front - my son was in the passenger seat and put his window down - the noise really did seem to be at the front Confused
Sorry, forgive my lack of knowledge, but is the "rose joint" the same as the "hub joint" as per posts above ??
Thanks
Post #353798 23rd Oct 2015 11:54am
