![]() | Home > Technical (L322) > Slight hunting at 30mph by 100-200rpm.. (new vid page 2) |
red_slr Member Since: 06 Oct 2010 Location: Manchester Posts: 42 ![]() ![]() ![]() |
Well spent the whole day changing the brakes. All friction components now brand new to OE spec. Not made a jot of difference.
Been told to try a gearbox flush...
Just an update this issue is still ongoing.
Well, still got this problem even after changing the O2 sensors.
New video.
Just to add some more detail to this. I just let the car cool off to cold.
Does this engine have a CTS (coolant temperature sensor) Earlier Rover/Range Rovers had them and they could cause hunting and over fuelling problems, they were less than £15 to replace. It would be worth checking if this engine has one fitted and if so change it |
I think so, its part of the thermostat housing isnt it? Range Rover Vogue 4.4 (2003) |
It's not the coolant temperature sender unit, that is a different item which sends the temperature back to the temp gauge on the dash.
Um, not sure TBH. Will have to do some digging.. Range Rover Vogue 4.4 (2003) |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
My first thought are throttle pot worn.. though I'm not sure if its fly by wire or cable though strongly suspect it would have a pot.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Probably not relevant to the RR, but my 3200 Maserati did this, it was a combo of the throttle pedal potentiometer and the throttle body feedback pots. Mind you although it was drive by wire, they had mechanical feelers on resistive strips that wore through causing limp home mode and erratic idle. I'd guess the RR uses digital hall sensors not mechanical ones. 2006 Mercedes CLS
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 ![]() ![]() ![]() |
Hi my car (2002 range rover 4.4 HSE ) has just started to do this and very annoying it is. I serviced it about a month ago including radiator flush and gearbox oil change. It is exactly the same fault as described by the Op. I have a Hawkeye diagnostics and it shows no engine or gearbox faults. Did you manage to cure it?
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
Why not go back to basics, start with fuls and air ? Is it getting the same contnuiouse amonts of both ? Could it be being starved by one or the other or getting surges of one or the ther ? |
