Home > Technical (L322) > Mirror lamp LED's
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Mirror lamp LED's
Hi all,
I've read numerous posts about LED upgrades and have already done most of the interior lights. I changed the drivers side mirror Light but ran out of bulbs so didn't do the passenger side. Everything was working fine and today I changed the remaining lights including the passenger mirror.
Now though the mirror lights don't work properly. When I unlock they flash but go off immediately. I've tried different bulbs to no avail. Has anyone else had this problem and if so did you get around it?
Thanks in advance Very Happy
Post #349612 27th Sep 2015 12:12pm
n1cktdv8
I tried a host of bulbs in my puddle lights (in the mirror) and didn't find a single one that worked well...same with reverse...and as such I have every other bulb in the car as an LED except the puddles and reverse Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #349620 27th Sep 2015 12:46pm
Fish
Thanks.
I decided to swap the passenger side back to a normal bulb and it still only flashed. I changed it for another and now they are working ok so I'll have to live with one normal bulb Wink
Post #349675 27th Sep 2015 7:00pm
I rewired my mirrors to the puddle lights in the lower door panels... They then worked every time i opened the door rather then timing out! & secondly no more bulb issues Whistle Thumbs Up
Post #349720 27th Sep 2015 11:59pm
proser
Thanks for that info Craig, will be looking to do mine soon Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #349738 28th Sep 2015 9:23am
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I changed my bulbs to LED ones yesterday,they only had 3w ones but the difference is huge my puddle lights now light up the most of the side of the car ,You have to force them in a bit but doesn't affect the bulb holder and there doesn't seem to be any right/wrong way to do it
http://www.halfords.com/motoring/bulbs-bla...-car-bulbs L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #349780 28th Sep 2015 2:41pm
proser
Do they work without any problems ?? Regards
Mark
2012 Westminster
Post #349785 28th Sep 2015 2:56pm
Ivor
yes no problems at all ,my puddle lights have always come on and stayed on until i put the key in the ignition and they still do L322 2008 vogue
Post #349787 28th Sep 2015 3:01pm
Robgosty
Are these the correct ones for the mirror puddle lights, tried a few different types but had no joy, can someone confirm these actually work Thumbs Up or better still a link to some cheaper ones that work Thumbs Up
Post #355511 5th Nov 2015 7:35pm
5c0tty
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
hi guys,
i have these LEDS in my RR and they work great! They light up a lot of area too!
Post #355943 9th Nov 2015 10:15am
i think i have found a solution for leds not working in the mirror lights..
i fitted one led in the drivers mirror and it worked perfect...then when i fitted the passenger side both the leds would flash and then go out..
solution is to wire in one of the old bulbs in parallel with one of the leds ...this seems to fool the system [resistance?] and makes both the leds work...
on the old bulb you can bend the connection wires out and solder a short piece of cable onto them and then splice onto the mirror cable.. ... - .- -.
Post #356117 10th Nov 2015 7:03pm
Robgosty
Worked for me, nice bright mirror LEDs, plenty of room for bulb inside mirror housing, well done Stan Bow down Thumbs Up
Post #356256 11th Nov 2015 1:48pm
thanks Rob..i reckon a small resister will also do the job.. ... - .- -.
Post #356265 11th Nov 2015 3:05pm
monty1562
United Kingdom 2007 Range Rover Autobiography TDV8 Zermatt Silver
Thumbs Up you beat me to it stan, I did the same thing on mine, works like a dream!
Post #356405 12th Nov 2015 11:36am
Thumbs Up ... - .- -.
Post #356407 12th Nov 2015 11:41am
