Home > Maintenance & Mods (L322) > Replacement High Beam Bulb
Page 1 of 4 1234>
supershuttle
My car has xenon dipped but main beam is a halogen bulb. The xenon is "cold" and the halogen is "warm" or blueish and orangeish if you prefer. whats the best choice for replacing the halogen to achieve a more blue light?
and Wattage - i've seen some blue 100W anyone tried them? Geoff
Post #349442 25th Sep 2015 10:40pm
I have a great Phillips 5k xenon kit replacing my halogen full beam bulbs, I also replaced my headlamp bulbs with 5k Phillips ones... Brilliant upgrade... Thumbs Up
These work mainly because The halogen high beam bulbs do VERY little in terms of light! But the xenon's put out 3-5 times more light then the halogens they replace... The original halogen bulbs are kind of overpowered by the flapper motors in the headlamps which create the lions share of light when the full beam is engaged... So this negates the couple of seconds needed for the xenon bulbs to warm...
The end result is very powerful full beam lights now Thumbs Up even to the extent of feeling like the headlamp are poor when you have traveled a fair distance using full beam Rolling Eyes
One of my favourite upgrades in bad weather Thumbs Up
Post #349444 25th Sep 2015 11:27pm
i use normal 55 watt white halogens , loads on ebay at around £8 for the pair.....
you do know that the main beam is 'lost' in the brightness of the xenons ... ... - .- -.
Post #349454 26th Sep 2015 7:18am
supershuttle
Thanks Stan, it's not entirely lost but I probably notice it because it's as orange as Dale Wintons tan: in fact it's a lot like Dale Wintons tan, brings little to the party apart from an orange glow Rolling with laughter Geoff
Post #349468 26th Sep 2015 9:08am
Zirconblue
It's not really a 'main beam', because they're Bi-xenons - the xenon does both the main and low beam by way of a motorised shutter, that masks off part of the beam when you 'dip' them.
The halogen bulb is described as a 'fill in' bulb, as it supposedly lights up more quickly than the shutter can move out the way of the xenon bulb. I suppose we're only talking fractions of a second, but it's just there to stop the main beam appearing laggy from what i can gather.
Post #349469 26th Sep 2015 9:15am
Lost for Words
The shutters are pretty instant, but since HID takes time to warm up, it's unable to flash when the lights are off, so the halogen is there for that too.
Additionally though, the colour rendering of halogen is far superior to HID (or LED), and the lower kelvin temperature light is better processed by the human eye, so be proud of that orange glow; it is helping with HID's shortcommings. Smile Wink
Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #349472 26th Sep 2015 9:24am
supershuttle
Thanks for the replies but I probably need to add that I realise that this is only a cosmetic change and the the "main beam" halogen does little or nothing compared to the bi-xenons. So the posts confirming that are a bit superfluous to my needs, all I want is a bulb recommendation for the H7s so that the colour is similar to the xenons. Thumbs Up Geoff
Post #349474 26th Sep 2015 9:29am
i got something like these Geoff,
http://www.ebay.co.uk/itm/2-X-H7-499-477-5...235731c119 ... - .- -.
Post #349534 26th Sep 2015 9:13pm
supershuttle
Excellent, thanks Stan. Thumbs Up Geoff
Post #349581 27th Sep 2015 8:10am
@ CTC,
I like the idea of changing the H7 mainbeam tungstens to Xenon with a kit. Thumbs Up
Have you a link to the kit you used by any chance?
Thanks.
Post #349618 27th Sep 2015 11:20am
miggit
I think these are the bulbs CTC is on about, I had some in a car a few years back and they are a lot whiter than std. Thumbs Up
http://www.ebay.co.uk/itm/Philips-Diamond-...5418eb3861
But hunt around as I'm sure you can get them cheaper, plus I personally wouldn't do the HID route, you may get the right colour, but they wont "flash" because they have to warm up Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #349627 27th Sep 2015 12:57pm
Lost for Words
Ditto the above, and also for the reasons I posted above, but if you really want to go for an HID kit, make sure it's a decent one, like these: http://www.hids4u.co.uk/h7-xenon-hid-conversion-kits/ (DISCO315 Wink ) It's important that effort has been made to ensure the arc is in the correct place, and cheapo ballasts will give poor bulb life, and performance. Thumbs Up Visiting from DISCO3.CO.UK
Post #349635 27th Sep 2015 2:20pm
miggit
Shocked Shocked ^^ How Much Shocked Shocked
For reasons of bank balance, I'd stick with the normal Xenon bulbs and they react quicker than HID, and if your optically challenged you can get 100 watt bulbs for off road use Whistle and you could afford to get a spare set and still save 50% on HID Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #349641 27th Sep 2015 3:41pm
miggit
I've just gone for a set of Stan's ones cos they is shiny and I'm a tightwad Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #349644 27th Sep 2015 3:45pm
I just fancy the idea of significantly more light on the front end without resorting to auxiliary lamps. I never flash headlights at anyone so that's not a problem. As the conversion would only be on the main beam, causing glare to other road users shouldn't be a problem either.
Will give it some thought. Thumbs Up
Post #349645 27th Sep 2015 3:45pm
Page 1 of 4 1234>
