![]() | Home > Maintenance & Mods (L322) > Reversing Lights - is a LED bulb available? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
i dont think there is one that makes a great deal of difference..
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yes their are error free replacement led bulbs on flea bay.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I tried the cob type and was pretty underwhelmed....I have replaced all but the reverse and puddle lights.... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
At this moment in time there is no plug and play remedy for the dim reversing lights, you either stick with the poor lights that are fitted, put bigger wattage bulbs in them, but they will melt |
this is my attempt and like nick i was a bit disappointed.
Stan Mate would you like some 36 led 6w cob panels, you can get 2 in each lamp, and they is well bright |
thanks Paul but i do have an array of cob/smd panels to play with...i only put two panels in mine cos they fitted nicely into the 'curved well' on the light unit..
Just remember the golden rule that bigger is better, except overdrafts and waist measurements |
Dean, I was looking in to producing some led units, but the lamps are Land Rover only parts, as there aren't that many ffrr's out there, no one has started to produce the lights |
Dean Member Since: 23 Mar 2014 Location: Glasgow Posts: 51 ![]() ![]() ![]() |
Thanks guys for your responses,
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Has anyone ever tested the reverse camera with an IR source?
i have a separate infra red light for my cctv cameras and its works very well so i cant see why it wont work for the FF's camera but if you wire one of these up you might as well wire up an additional light.. ... - .- -.
