Home > Maintenance & Mods (L322) > Spark Plugs Stiff and Difficult to undo - SOLVED |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
No 6 plug is very very stiff but started to undo a fraction of a turn.
22nd Sep 2015 9:52pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1242 |
Good luck!
22nd Sep 2015 10:46pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
If in the very unlikely event that you have stripped the cylinder head thread all is not lost.
22nd Sep 2015 10:47pm |
Thank you Gentlemen for your time ...
23rd Sep 2015 9:25am |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
try putting the rest of the plugs back in and running the engine up to temperature and and then taking the plug it usually frees them up on most engines L322 2008 vogue
23rd Sep 2015 10:09am |
Thanks Ivor. I had warmed up previous cars but due to conflicting Internet info I found suggestions that the bmw alloy was better left cold.
24th Sep 2015 6:02am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi SMUTT haven't tried it myself, but some people I heard of have used coca cola, soak overnight, mechanic did it on my sons audi when he couldn't get the injectors out. It worked.
24th Sep 2015 6:12am |
I use the cup of tea method when removing the bottom off of skyline engines apply pressure have tea come back apply more pressure have tea and repeat until it comes off ,theres also a spray called shock and unlock it's basically a freezing spray same principle as heat except reversed L322 2008 vogue
24th Sep 2015 10:30am |
@gregdav - thank you - I had heard stories of people getting old engines that had sat rusting, to work using coke to free them - basically removed spark plugs and poured coke in the cylinders - left for a while, and it freed them up.
24th Sep 2015 10:32am |
@Ivor - thanks for your input. I have a theory similar to that that the tiny twisting movement you induce needs time to work its way through the whole fixing. By applying too much movement in one go leads to - well hell sometimes! Howard
24th Sep 2015 10:34am |
50/50mix of diesel and ATF is an excellent releasing agent |
24th Sep 2015 11:42am |
@47p2 - thanks for the input.
25th Sep 2015 4:25pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
well done that man....
25th Sep 2015 5:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8107 |
Well done Howard, glad you got that out OK... Pete
25th Sep 2015 5:42pm |
