Home > Technical (L322) > Trans Failsafe Prog - 2004 RR 4.4 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
you'll find this is a very common error message and could be a number of causes, try a search.. ... - .- -.
24th Sep 2015 8:03am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
A failing inhibitor switch or low battery voltage would be my guess. It would be worth checking if a P0705 error is stored in the controller.
24th Sep 2015 8:22am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
I have heard that allowing the car to go through it's electronic checks before actually starting the engine can help solve spurious messages.
24th Sep 2015 8:54am |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
I bet it is the xyz range switch - as suggested check for codes |
24th Sep 2015 6:27pm |
