Home > General (L405) > RR Vogue Headlamp adjust for driving abroad
kajagoogoo88
Picked up the new car today and slowly working my way through the handbook. Pulling my hair our cos I can't find the driving abroad headlamp adjust function as detailed in the handbook page 67.
I only have the basic Vogue so it may not be fitted - but the book says "The headlamps have a beam pattern that eliminates the need to mechanically adjust the lamps or add any external stick-on decals". Doesn't make reference to selected models only.
It then goes on to describe how to do this using the Menu control on the steering wheel, select Driving Features, select auto high beam setting, select Drive on Left or Drive on Right.
I don't have anything in the menu that allows me to select auto high beam setting. I get to Driving Features and only have 2 options neither of which is to do with headlamps.
If its not available on the basic Vogue, it would be kinda nice if they would say......
Help me. Goin crazy.
K Current:
2012 RR 4,4V8 Westminster)
2007 Bentley Continental GT 6.0 W12
1998 Jeep Cherokee 4.0
2018 Maserati Ghibli 3.0 V6 Gran Lusso
2017 Aston Martin Rapide S. Shadow Edition
Post #349110 23rd Sep 2015 4:34pm
Sorry sir, I don't know but would be interested to find out your results Bow down
Post #349120 23rd Sep 2015 5:42pm
Beam pattern is apparently symmetrical so doesn't need adjusting for the continent.
However, if you have automatic high beam - you do need to set that, so I assume it must need to know which side to look, or at least give higher priority to for dipping the beam due to oncoming traffic
Post #349144 23rd Sep 2015 8:00pm
That said - you may still get flashed as the lights are bright - particularly if they are not properly adjusted - it's quick & easy to point them down a bit more - you just need a screwdriver and a dark bit of road or a wall Thumbs Up
Post #349146 23rd Sep 2015 8:02pm
