![]() | Home > In Car Electronics (L322) > Trailer wiring problem |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
After a couple of hours going round in circles I am taking a time out as I am getting nowhere fast.
Thanks for the input, My understanding is the Light control module (LCM) detects the brake pedal is depressed and sends a signal to the trailer ECU which in turn sends power to the trailer plug. I have T`ed into that feed at the LCM to get the signal for the electric brake controller which works. I am not getting the power out for the brake lights from the trailer ECU presuming its the red wire. I might just bite the bullet and take off a feed from the rear cluster. 2007 TDV8 VSE
You could test for an output at the trailer pick-up socket, adjacent to the ecu in the rear compartment.
Thanks for that, I might be looking for a bad connection in the wrong place, I did not realise that white plug was the feed to the trailer socket. 2007 TDV8 VSE
Just had another look and it looks like the LCM feeds to the white plug, the trailer ECU connects to the white plug, the trailer plug connects to the trailer ecu so I should get power for the brake lights from the trailer ECU ( RED? ) not the white plug. 2007 TDV8 VSE
I don't think that is correct.^
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Brake lights are on pin one of the trailer ecu socket, so what ever colour that is |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I've just fitted a brake controller to my MY12. I picked-up the brake light feed from the red wire at the trailer harness's white harness connector that's located at the back of the spare wheel well. Earlier model trailer harnesses may be different though. |
Ok all good, I feel a bit stupid but I will excuse myself this time.
Good to hear you got the problem sorted. |
