Home > In Car Electronics (L322) > USB Music - Solved
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
USB Music - Solved
I've been getting a little frustrated recently, failing to be able to play music from both my iphone or a USB memory stick, reading around lots of people have intermittent results, but now i've solved the problem.
I have quite a collection of music, and upto this point have been frustrated that i could only add a few MP3 formatted CDs.
I went on to ebay and ordered one of these, 512GB USB drive, it was only £7. For half a Terrabyte.
http://www.ebay.co.uk/itm/512GB-USB-Flash-...2a5518c680
When it came, it had a virus on it, dont worry, we are going to format it, but to be sure, run a AV check once you have attached it to your computer.
The Rangie only reconises FAT32 file systems, so you need to format your USB drive to FAT32. The only issue is that windows only allows you to format FAT32 systems upto 4GB. I found this handy little utility which gets round that limit. Download and use to format your removable drive. You can get away with a quick format, which only takes a few seconds, a full format would take ages.
http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm
Last thing is that the player only seams to recognise mp3, so no ACC, flac or apple files, however, unlike burning a mp3 CD, the system does support a directory structure, so copy them accross.
It took around 5 hours to copy all of my music over, but adding it to the car it works a treat. __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #348539 19th Sep 2015 4:35pm
Good work DaveAngel Thumbs Up
Useful little utility that, LR are so being the times with their tech even on the newer ones!
HTF do they get 512GB into that tiny stick Shocked .
Post #348547 19th Sep 2015 6:08pm
DaveAngel
I know! I come from the days of c90s, and remember paying hundreds for my first 20Mb (I do mean megabyte) HD so was waxing lyrical to SWMBO about the size of this sub stick, but she couldn't care less.
It's good though 'cos it doesn't stick out in the glove compartment to get broke off. __________________
2015 FFRR SDV8
Post #348552 19th Sep 2015 6:50pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just a word of warning with these to good to be true prices on memory. In my experience they look to be the advertised size, ie 512gb when checked on a pc but they will be a fraction of that in reality. They will work, look to load loads of stuff then fail in short time.
https://youtu.be/uencT8VZ43s 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #348578 20th Sep 2015 12:24am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
As wayneg says I would seriously doubt it is 512gb. Sorry to put a damper on the party.
I have my own data recovery business so I see plenty of fakes.
Fine for storing none critical data ie you have a backup elsewhere but you will reach a critical volume say 32gb after which the device will corrupt the data on it or simply not work anymore.
You can check the device yourself in any free disk editor Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #348583 20th Sep 2015 7:57am
DaveAngel
Well, mine is 499Gb when formatted, and I have 135GB of music on there and it working fine.
Would I use it for critical data? No chance, but for music in the car, for seven quid, do you care? __________________
2015 FFRR SDV8
Post #348587 20th Sep 2015 8:17am
wayneg
DaveAngel, sorry Mate but its a well reported con, did you watch the video in the link? have a read of the ebay fake warnings????
http://www.ebay.com.au/gds/All-About-Fake-...258/g.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #348591 20th Sep 2015 8:54am
And not only a size issue, they can also come with some malware, ready to be clicked and ruin your hosts file and browser. Evil or Very Mad .
Post #349828 28th Sep 2015 6:11pm
