Home > Technical (L322) > How to identify the navigation disk year
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi,
How can I identify my navigation dvd year, I ejected the disk, but I could not see a date printed on the disk label (it is an original). So is there a way to read the date from the touch screen display, I had a poke around the menus but could not see anything obvious?
Assuming my disk turns out to be the original that came with the car (2006), will a new disk update the firmware, if so will I see any differences / new features on the display?
Many thanks,
Justin
Post #34772 3rd Nov 2010 11:09pm
InVogue
I have a 2004 car, the DVD disc itself is marked (c) 2004 Denso and (c) 1993-2004 Navteq. I suspect you can infer the date from this copyright notice. Maybe others more knowledgeable than I can tell you from the part number on the DVD. In any case, I think it would be worthwhile upgrading to the latest disc.
Post #34779 4th Nov 2010 12:27am
doublejay
pop it in your computer Thumbs Up .......there no significant features, just map data
Post #34794 4th Nov 2010 9:06am
InVogue
Forgot to add, if you upgrade to a later disc, yes it will update the nav firmware automatically. I did so, and it enabled destination entry on the move, which was not available on my original 2004 disc. Thumbs Up
Post #34801 4th Nov 2010 10:18am
incorrect.... destination on the move is dis-enabled if you upgrade to the 2009/2010 map disc/firmware...but, you can have it enabled at a dealer... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #34803 4th Nov 2010 10:27am
doublejay
Agreed. I lost that hack after the upgrade.
Post #34812 4th Nov 2010 1:06pm
InVogue
Embarassed Sorry, my mistake, you can't select new destinations on the move, only previous destinations and memory points.
Post #34888 4th Nov 2010 8:33pm
JustinP
The date of my disk is 2005, which I guess was the most up to date disk when my car was new (2006), so it needs replacing.
Is there anywhere cheaper than Land Rover to obtain a replacement?
Post #34889 4th Nov 2010 8:38pm
