Home > Technical (L322) > creaking suspension |
Most likely a bottom balljoint on its way out. You should get it investigated sooner rather than later |
2nd Nov 2010 8:01pm |
You'll get a clunk from the front rather than a creak I would have thought.
2nd Nov 2010 8:26pm |
Creaking balljoints are common and once they start its best to have them changed as soon as possible. I had one on my TD6 that was just starting to creak when I replaced it |
2nd Nov 2010 8:37pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
yep its your front lower balljoint, just done mine to get rid of the creak. 2004 black Vogue TD6 |
2nd Nov 2010 9:55pm |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
thanks for the response is it a easy job doing the ball joints |
3rd Nov 2010 8:00pm |
Technically easy but can be a PITA getting the balljoint off, your need a ball joint splitter and be carefull you do not damage the boot above.
3rd Nov 2010 9:01pm |
specman Member Since: 20 May 2010 Location: Fife Posts: 250 |
If you are getting the noises do the lower ball joints as mentioned.
3rd Nov 2010 10:09pm |
This noise is not a clunk its like an old door closing and the strange thing is it only happens when i turn the steering wheel tto the right it does not make a noise when i turn to the left on listening it also appears to be comming from higher up than the ball joints
4th Nov 2010 6:43am |
If its creaks when stationary then get someone to wiggle the wheel while you hold each suspension arm, you should feel the vibration at the same time as the creak. Failing that you might need to get it on a ramp mate..Good Luck.. 2004 black Vogue TD6 |
4th Nov 2010 7:46pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2035 |
Does seem strange.
4th Nov 2010 8:28pm |
Hi Guys
5th Nov 2010 9:06am |
Its was balljoint but you orderd track Rod ends? |
21st Nov 2013 6:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
holy thread revival batman.
21st Nov 2013 7:00pm |
Thats the beauty of search Stan rather than a new thread.... |
21st Nov 2013 7:01pm |
