![]() | Home > Technical (L322) > Testing headlight levelling ecu |
From what you describe I think you need to set the direction of the headlights manually to bring the level of each down.
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 ![]() ![]() ![]() |
@nicedayforit - thanks for the reply, will have a look at setting them manually. As the (headlight levelling) ecu only makes minor adjustments can it be simply unplugged or would that make the main LCM (light check module) throw a wobbly |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
It could create a fault with the LCM yes, but... 99.5% of systems don’t work from factory on pre 05 cars anyhow! So as suggested above, it sounds like your lights are simply poorly adjusted sir... |
As above, I would be inclined to do nothing as regards the ecu, chances are the self leveling is not working anyway.
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
"Tourist Button"?? |
Mike, the OP clearly states in his original post that he has read and understood the thread about the tourist button sir |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35459 ![]() ![]() |
Mike is questioning the 'button' not referring that this is the solution Craig..
Ah! Tourist Lever gets a few hits in the search. Tourist Button got nothing hence my confusion.
yes tourist lever - apologies - my mistake |
