![]() | Home > General > Potential new owner |
That's a very nice looking car and with low mileage too. Good for you! |
Sounds like a nice car.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Mine has Scorpion Zero's (which all have the M&S logo i believe), no obvious tyre noise.
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 ![]() ![]() |
Thanks for the replies, I have checked all fans where turned off, all windows and roof closed, the noise seems to be not too bad at 50 mph but 60 upwards it is quite intrusive. Tyre pressure as recommended 33psi front, 36psi rear. I must admit I changed the wheels on the Disco from 20" to 19" to make the ride softer. I wonder if 19" wheels would make any difference on a Range Rover it does not sound like a mechanical noise ie engine, gearbox, bearings etc. maybe I will get used to it. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
Could it be wind noise ?
Larger profile tyres will always offer a better ride at the expense of handling and vice versa on any car.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I had a problem with what I thought was tyre noise. It wasn't. It was the plastic cowel at the base of the windscreen. It vibrated at speed and seems to be a known problem. I had the piece replaced and it became MUCH quieter. It was only a problem at about 50 mph +. |
