![]() | Home > Technical (L322) > 4.4 V8 petrol won't start |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
If you are hearing the starter clunking but not turning, it's very likely the starter is at fault. There are two actions it performs, firstly, it has a sliding solenoid, that flicks in the drive cog, and then a pair of contacts are engaged at the end of that action, to then spin the motor. If these are not in GOOD connection, or the motor has failed then it won't turn the engine. Releasing the key, 'uncluncks' the solenoid. If you can see the motor from underneath. The old way of proving this was to use a block of wood and a hammer to thump the motor to jog it a little and make the connection, to prove the fault, and get you temporary moving. |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
Thanks for your response. The starter sounds very strong and is definitely not struggling or clunking. Now: BMW 640d M Sport, Alpine White
So you hear no clunk or spinning sound? The clunk would only be the metallic action of the solenoid. To me if the starter is doing something, it is past the immobiliser. If you look under bonnet, does the fan spin at all, I mean just a tiny bit? |
I 'think' I've narrowed it down to a fuel filter/fuel pump issue but it's one for Saturday now... Now: BMW 640d M Sport, Alpine White
i had the in-tank fuel pump give up on me, spinning over, but no fire. easy test, remove engine cover, and put on ignition. there should be a small air valve shraeder on the left front of stainless fuel rail. if you press it with a small screwdriver, fuel should spurt out properly, and continue to do so. (into a big cloth above) if its not you need to look up the wiki, fuel pump change. could be just the relay in the boot on the right on the fuseboard. switch it around. you can buty a pump for about £45 pattern part. its a bity of a job, but its do-able. I proved mine by probing the fuel pump block connectors for voltage. (12v and earth) (under rear seat.) you can also prove it, by spraying in some easy start to the air filter. a three second spray should give it enough to fire.
FYI for anyone experiencing similar - it turned out to be the fuel pump, after replacement with a new one all is working well. Now: BMW 640d M Sport, Alpine White
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
Andy
if you read above the remedy re fuel pressure, get someone in the know to assist you,. try that method, or you could just spay easy start into the MAF area after starting to see if it continues to run, on a jet of easy start etc. meaning you have not enough fuel through the injectors, perhaps fuel pump. -they are dear for the whole assembly, or you can change just the actual pump motor, for around £60 search threads, and see the fuel pump wiki. |
